Cable for Broadband
I ordered broadband VM and I checked if VM provided my building and it does. In my flat the only thing I found was a cable that looks exactly the same as the cable I am supposed to put into the Wall Socket. Is there a chance to buy a cable that connects the two?
  • 14.9K
  • 1.17K
  • 3.48K
Re: Cable for Broadband
post a picture - there should be a wall box but these sometime get removed just leaving the input cable - this then will not connect to the supplied cable as i think you are saying
if thats correct then this should sort it - https://www.diy.com/departments/tristar-data-cable-coupler/571706_BQ.prd
____________________
Tony
