on 22-10-2022 18:22
Just moved house and received our QuickStart kit. The previous owner had Virgin Media too - there is a cable already plugged into the VM socket on the wall which says CABELCON 3.9. This runs into what looks like an adapter, which then has 2 other cables coming from it. Should I unplug the cable from the wall and plug in the isolator cable that came with my kit, or plug the cable that was already here into my Hub? If I do unplug the existing cable though, how will we get Freeview?
on 22-10-2022 18:34
For neatness it would be better plugging in the existing cable in.
on 22-10-2022 20:26
Thanks for the reply. I've tried unplugging it but I can't remove it. Think I'm going to need an engineer to come and sort this. How can I arrange this please?
on 22-10-2022 20:55
I don't understand, you should be screwing in the black wire thats already there, can you explain what you can't do?
on 22-10-2022 21:54
It’s an old connection which is screw, new one just push on over the threads.
on 22-10-2022 22:29
So sorry, I read your post as 'unplug the existing cable'. Will try plugging in the existing cable.
on 25-10-2022 09:22
Hey Luisa3, thank you for reaching out and a warm welcome to the community, I am sorry to see you are having some issues setting up your kit.
How did you get on with the last step, do you still need some assistance? Thanks
Matt - Forum Team
New around here?
