  • 11.14K
  • 1.49K
  • 4.81K
Message 11 of 17
Re: Broadband Problems
For now the best thing is to move this thread to a more appropriate part of the forum.  So, I will do that now.
_________________________________________________________
Graham
I am a VM customer. There are no guarantees that my advice will work. To say thanks click the kudos thumb. If I have solved your problem please click the helpful answer button.
  • 14
Chaserfree
Message 12 of 17
Thanks for joining in to try and help.
As a matter of interest do the list of errors on the Downstream table have any significance? I've just updated it and more have appeared as below:
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
38.6
53
4
2
Locked
38.6
9
0
3
Locked
38.6
40
0
4
Locked
38.9
23
0
5
Locked
38.9
12
0
6
Locked
38.9
13
0
7
Locked
38.6
13
0
8
Locked
38.9
44
2
9
Locked
38.9
126
0
10
Locked
38.9
32
0
11
Locked
38.6
267
16
12
Locked
38.6
92
17
13
Locked
38.6
76
5
14
Locked
38.9
104
8
15
Locked
38.9
108
11
16
Locked
38.6
51
8
17
Locked
38.9
380
3
18
Locked
38.6
69
0
19
Locked
38.9
293
23
20
Locked
38.9
102
11
21
Locked
38.9
97
18
22
Locked
38.6
118
0
23
Locked
38.9
161
16
24
Locked
38.6
1004
133
  • 11.14K
  • 1.49K
  • 4.81K
Message 13 of 17
No, i don't believe they do.  If you saw the number of post Rs errors shown on my diagnostic page you would be horrified.   Yet my connection works without issue.  So in your case something else looks to be the causeA VM staff member will get to this in a week or so and may be able to offer additional advice.
Password
Router status
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
12990000005.938256 qam21
23230000005.538256 qam24
33150000005.538256 qam23
43070000005.838256 qam22
52910000005.538256 qam20
62830000005.938256 qam19
72750000005.638256 qam18
82670000005.838256 qam17
92590000005.938256 qam16
10251000000638256 qam15
112430000006.338256 qam14
122350000006.438256 qam13
132270000006.438256 qam12
142190000006.538256 qam11
152110000006.538256 qam10
162030000006.538256 qam9
171950000006.838256 qam8
181870000006.938256 qam7
191790000006.638256 qam6
201710000006.938256 qam5
21163000000738256 qam4
22155000000738256 qam3
23147000000738256 qam2
24139000000738256 qam1
1Locked38.9143401
2Locked38.6109288
3Locked38.6101371
4Locked38.999416
5Locked38.9175365
6Locked38.9108379
7Locked38.992406
8Locked38.9113392
9Locked38.9113302
10Locked38.9153360
11Locked38.684373
12Locked38.9120474
13Locked38.9122352
14Locked38.9130348
15Locked38.9312392
16Locked38.9180283
17Locked38.6132389
18Locked38.6181421
19Locked38.9240386
20Locked38.9361274
21Locked38.9211324
22Locked38.6237487
23Locked38.9766331
24Locked38.9415520
Graham
  • 15.2K
  • 653
  • 32
Moderator (Retired) John_G
Moderator (Retired)
Message 14 of 17
Hi Chaserfree,
The stats you've posted look ok to me, I've tried to check everything from this end but your hub is offline so couldn't perform any tests. I can at least confirm there are no area faults open that are causing this.
Are you only seeing this over a wired connection or do you get the same drop outs when connected via ethernet cable?
  • 14
Chaserfree
Message 15 of 17
Thanks for looking.
I’m away from home at present which is why my hub is turned off. I get the problem both on my desk top which is connected by an Ethernet cable and my I-pad which is wireless.
I’ll be back late tomorrow if you could possibly check again sometime after that.
  • 14
Chaserfree
Message 16 of 17
I don't know if you have tweaked something or it's coincidence but things are much better since my return this week.
Just occasionally have to click a link more than once to get a response but otherwise, so far, nothing like the problems I had.
  • 10.32K
  • 279
  • 588
Forum Team (Retired) Emma_E
Message 17 of 17
Hi Chaserfree,
Thanks for getting back in touch, I am glad to see things are looking better for you now.
If you need any help in the future we will be happy to take a look for you
All the best
Emma
