  • 14
Chaserfree
Message 1 of 17
Broadband Problems
Hope this is the right board, I'm not techie but hopefully someone who is may have suggestions.
I've been having intermittent problems opening web pages for a few weeks. Sometimes I get message "waiting for response from...". Sometimes the page I want appears in the address bar but my screen still displays the page I want to leave. Sometimes just a blank page.
At first I thought it might be ebay because I use that a lot but I'm getting it everywhere.
I don't think it's my pc because I have the same problem with my I-pad.
Sometimes turning the modem on and off helps for a while.
Some days it works fine with no problems but not often.
I tried phoning the helpline and the automated message said a check was being run which would take a few seconds. Then it said it was taking longer than expected and wait a few seconds more but then the call was dropped.
I've checked service status for my area and it says there are no known issues.
I ran the service check tool on Virgin which crashed the first time but second time said there was no issue with my connection.
What do you think I should do next.....arrange a visit from an engineer?
Chaserfree
  • 11.83K
  • 897
  • 2.52K
Message 2 of 17
Re: Broadband Problems
log into hub3 - 192.168.0.1 [or 192.168.100.1 if in modem mode] - DON'T SIGN IN, click - click router status [centre of screen] - and post the downstream and upstream figures - to see those press on the grey buttons/boxes labeled - upstream - downstream
if its an earlier hub button is top right
____________________
Tony
  • 14
Chaserfree
Message 3 of 17
Hi Tony,
Thanks for getting back to me so promptly.
You say "don't sign in" but it won't let me past the Welcome page unless I do.
Chaserfree
  • 11.83K
  • 897
  • 2.52K
Message 4 of 17
top right of screen if its a SH 1 or 2 or under where you enter the password on a hub3
Tony
  • 14
Chaserfree
Message 5 of 17
OK so I've entered password and am into the hub but the hub status is just a display and can't be clicked on.
I've clicked in some of the advanced settings but can't see anywhere that I can see upstream and downstream figures and I'm nervous of making unwanted changes.
What I see is this:
  • 11.83K
  • 897
  • 2.52K
Message 6 of 17
ok its a hub3
so another way - once you get to first screen you see a white box with an area to enter password - below and outside that white box it says
> Check router status
its not obvious but thats a button click on it and follow instructions above about downstream and upstream levels you will see
Tony
  • 14
Chaserfree
Message 7 of 17
Whoops now I see it.
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
147000000
0.7
38
256 qam
2
2
155000000
0.9
38
256 qam
3
3
179000000
1.2
38
256 qam
6
4
195000000
1
38
256 qam
8
5
211000000
1
38
256 qam
10
6
235000000
0.7
38
256 qam
13
7
251000000
0.5
38
256 qam
15
8
307000000
0.2
38
256 qam
22
9
163000000
1
38
256 qam
4
10
171000000
1.2
38
256 qam
5
11
187000000
1.2
38
256 qam
7
12
203000000
0.9
38
256 qam
9
13
219000000
1
38
256 qam
11
14
227000000
0.7
38
256 qam
12
15
243000000
0.7
38
256 qam
14
16
259000000
0.4
38
256 qam
16
17
267000000
0.4
38
256 qam
17
18
275000000
0.2
38
256 qam
18
19
283000000
0.4
38
256 qam
19
20
291000000
0.4
38
256 qam
20
21
315000000
0.2
38
256 qam
23
22
323000000
0.4
38
256 qam
24
23
299000000
0.4
38
256 qam
21
24
139000000
1
38
256 qam
1
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
38.9
4
0
2
Locked
38.9
1
0
3
Locked
38.6
5
0
4
Locked
38.9
4
0
5
Locked
38.6
5
0
6
Locked
38.6
6
0
7
Locked
38.6
7
0
8
Locked
38.6
6
0
9
Locked
38.6
4
0
10
Locked
38.6
6
0
11
Locked
38.9
7
0
12
Locked
38.6
6
0
13
Locked
38.9
5
0
14
Locked
38.6
6
0
15
Locked
38.6
8
0
16
Locked
38.9
6
0
17
Locked
38.6
5
0
18
Locked
38.6
5
0
19
Locked
38.6
7
0
20
Locked
38.6
22
0
21
Locked
38.6
19
0
22
Locked
38.6
9
0
23
Locked
38.6
1
0
24
Locked
38.9
8
0
  • 14
Chaserfree
Message 8 of 17
Here are the Upstream:
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
39400000
42.8
5120
64 qam
10
2
25800000
40.3
5120
64 qam
12
3
32600000
41.3
5120
64 qam
11
4
46200000
42.8
5120
64 qam
9
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
  • 4.78K
  • 371
  • 788
Superstar
Message 9 of 17
All those stats are very good.
There are 10 types of people: those who understand binary and those who don't and F people out of 10 who do not understand hexadecimal
  • 14
Chaserfree
Message 10 of 17
Hi Tudor,
Well, thanks for checking the stats but actually wish they had showed up a problem because something's wrong. I've been trying for a couple of days on and off to tax my car on the DVLA website. Eventually got through to the payment screen when it froze again. Then I didn't know whether my payment had gone through or not until an email arrived. I've just had three attempts to run a Google search and that's usually the easiest thing to do.
I rang 150 but the call centre guy in India ran a test and said there's no problem.
So I have no idea where to go from here.
