reiver1
wifi stopped working after remote reset
My wifi has been working fine until my husband called technical help about another issue, they did a remote reset, when we got home all wifi was out, could not connect phones, computer or laptop, it was working fine until the reset, after hours on the phone just told wait for a new router and if that doesn't work then will have to work through more things!! when we said not happy about the wait and no wifi etc we where put through to cancellations!!
Went through it all with them and again nothing sorted, so now left waiting!!
  • 9.59K
  • 1.01K
  • 1.51K
Re: wifi stopped working after remote reset
What Hub model is it Hub3 I assume. Switch it off for 5 minutes then on and see what the Hub lights are doing and report back. Als,o if it still isn't working can you check on a pc/laptop connected to the Hub by ethernet cable whether that is connected.
  • 11.8K
  • 1.08K
  • 2.56K
griffin
Can you connect via ethernet cables.
If a Factory Reset was done by the "support" team then all Wifi passwords\SSIDs would have been reset to their default values printed on the Hub.
  • 13.25K
  • 1.01K
  • 3.08K
hmmmmm - start with the basics - had you set your own ssid names and passwords on the wifi - if you had a remote reset or any kind of reset would have set them back to default
if you had not then log into hub and check wifi is turned on
finally for now if non of that works do a full reset - hold the button a good 30 sec dont guess time it and add a bit
____________________
Tony
