on 15-01-2021 14:12
ok-plug and play it says
white light on pod just keeps flashing white
been plugged in for 30 mins
will not connect to hub
hub has latest firmware
any ideas??
on 21-01-2021 19:55
Got mine a couple of days ago have the new firmware worked for a couple of days stopped working today... Wont reconnected. Tried reset etc and SSID's are the same.
on 21-01-2021 19:56
so same issue eh
i and my 2 sone have these pods
mine never worked
1 sons pod worked-even on split ssid
2 sons worked-then dropped out 24 hours later as its speed dropped to kbs not megs per second-he has removed his
seems best solution is to send back and buy a good mesh system
on 04-02-2021 21:52
on 04-02-2021 22:00
I was on the phone to them yesterday being passed from pillar to post, got put through to hub 4 in the end and she told me the pod was synced to my old hub 3 which was still on the account!?!? I haven't had a hub 3 since last year!! Anyway works fine, a little slow but Deffo need more than one
on 04-02-2021 23:54
on 08-02-2021 14:45
Hi all,
Sorry for the delayed reply. The pods are currently out of stock but will be back asap
Kind regards,
on 08-02-2021 23:09
on 09-02-2021 12:50
Hi there @Tazz
I am sorry that you're having some issues with your new Pods - I have located your account and can see that you have already called us about your issue and the appropriate checks have been done. As such, replacements are required.
As @John_GS advised, they are currently out of stock so we are unable to order these for you currently - I am sorry about any confusion caused.
Cheers
Katie - Forum Team
on 09-02-2021 19:18
on 09-02-2021 20:16
Hi @Tazz
Great to hear all sorted 🙂 have a lovely evening
