Lutos
  • 26
Message 1 of 10
wifi dropping out
Hello, I've been experiencing connection drops lately. Out of no where I lose my connection and after a few minutes it restores back, anyone help please.
  • 22.56K
  • 2.41K
  • 4.04K
Message 2 of 10
Re: wifi dropping out
you haven't said....
Are the issues only evident on wifi connections or do you see them at the same times on devices connected on ethernet cables? If you don't know, can you check to help diagnose whether it is just a wifi issue or it could be network connection related?
What Hub is it and what are the various Hub lights showing/doing when this happens?
Lutos
  • 26
Message 3 of 10
it affects wifi and ethernet and I think green lights is shown when this happens
  • 22.56K
  • 2.41K
  • 4.04K
Message 4 of 10
Might be a connection issue then. Have you checked first for “known network faults” As well as trying the “check service,” Area status webpage" (link at top right of this forum), also try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues down to postcode level. These may not be listed on the Area Status web page (Areas are not “Geographic” they are billing areas) as that usually only covers faults affecting 1000’s of customers) so phone may give you more info, but even that wont cover problems affecting just a few customers.
If nothing shows on there, try calling it in as a fault (free on 150 VM line - or 0345 454 1111 others - national rate) and see what they say when they test your connection. If they say it’s a known fault, get a fault reference number – n.b.- the UK call centre is still picking up and calling at 08.00 (Mon-Sat) or 09.00 (Sun) gives the best chance of getting through quickly.
lotharmat
  • 950
  • 70
  • 143
Well-informed
Message 5 of 10
Also, set up a 'Broadband Quality Monitor'. This will monitor the state of your connection and record any network dropouts etc - You can do this at ThinkBroadband (https://www.thinkbroadband.com/broadband/monitoring/quality)
Lutos
  • 26
Message 6 of 10
They didn't find anything and they suggested me to upgrade my plan...
lotharmat
  • 950
  • 70
  • 143
Well-informed
Message 7 of 10
Not again - what a ridiculous suggestion by CS!
C'mon VM - Please stop your CS agents from trying to solve connection problems with speed increases - a bad connection will just have a bigger speed problem!
Lutos
  • 26
Message 8 of 10
Dunno what to do now
  • 22.56K
  • 2.41K
  • 4.04K
Message 9 of 10
Post up your link to teh BQM "share live graph".
Just checking again - when the wifi connections drop out - what ethernet connected devices do you have - and do they retain network connection at the same time - or do they all drop out too?
And what colour is the Hub base power light and is it flasing or not - similarly the wifi lights?
Gareth_L
  • 6.2K
  • 380
  • 676
Message 10 of 10
Hello Lutos
Sorry you have been having issues with your services
It might be best to hang fire on the BQM as we have identified the cause
Your area has an SNR issue and is due to be fixed tomorrow 21/04/2021
This will be the reason your WIFI drops out
If you see how it is and if its no better Thursday, then we can chase it up again for you
Just pop back on here and quite this Ticket Number F008962264
Sorry again, We will have this fixed as soon as we can
Gareth_L
