  • 6.75K
  • 707
  • 1.04K
Legend
Message 21 of 29
Re: wifi comes and goes on phones and lap top
it should be there - see above piccy I just added.  Try another laptop/pc/phone ?
  • 31
mut2ley
Message 22 of 29
This is mad. Get same screen on mobile, laptop and PC. What the hell is going on?
  • 31
mut2ley
Message 23 of 29
also, why is it saying my password is wrong when it is right, if I try that way?
  • 19.59K
  • 2K
  • 3.71K
Message 24 of 29
@mut2ley wrote:
as you can see, here is the whole screenshot
To get the router status on the sign in screen, you need to complete the Hub admin setup.
So that's entering the Settings password and either changing it or skipping the change on the next screen. This'll then log you into the admin page if remember correctly, but the next time you go to sign in you should get the router status option before you sign in.
  • 31
mut2ley
Message 25 of 29
Hi BenMcr,
Thanks, that did the trick. Onto the next stage then.
  • 31
mut2ley
Message 26 of 29
Sama
@Samantha_L wrote:
Hi mut2ley,
Thanks for posting back here.
When I checked your connection, there have been no time-outs reported within 24 hours of the router being online.
Is the router left on at all times?
Do you notice any of the lights change on the router when the internet disconnects? If you can post the network log from the router settings that would be helpful. To do this type in 192.168.0.1 in the address bar, no need to sign in and click into Router Status in the middle. Within here you will have downstream, upstream and network log and you can copy and paste this information.
I want to help as much as I can to get this resolved for you.
Sam
To answer Samantha's questions....
  • Yes the router is left on at all times. New Hub3 installed on saturday.
  • No the light doesn't change
  • Channel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
    12987500003.936256 qam21
    23227500004.636256 qam24
    33147500004.537256 qam23
    4306750000436256 qam22
    52907500003.736256 qam20
    62827500003.536256 qam19
    72747500003.235256 qam18
    82667500003.235256 qam17
    92587500003.235256 qam16
  • 31
mut2ley
Message 27 of 29
Network log below won't copy and paste too well. do you need a photo?
Network LogTime Priority Description
1970-01-01 00:01:26.00Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:01:26.00Warning!MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:01:41.00criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-10-13 11:59:30.00noticeSW Download INIT - Via Config file
2018-10-13 12:01:58.00ErrorDisruption during SW download - Power Failure
2018-10-13 12:02:03.00noticeSW Download INIT - Via Config file
2018-10-13 12:04:04.00noticeSW download Successful - Via Config file
2018-10-13 12:48:18.00criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-10-13 13:53:00.00ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-10-13 14:19:01.00ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-10-15 05:07:28.00criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:01:28.00Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:01:28.00Warning!MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:01:42.00criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 31
mut2ley
Message 28 of 29
pstream bonded channels
14620000043.8512016 qam7
23940000043.8512016 qam8
36030000044.8512016 qam10
43260000043.3512016 qam9
1ATDMA0010
3ATDMA0000
4ATDMA0000
  • 11.7K
  • 347
  • 677
Forum Team (Retired) Samantha_L
Message 29 of 29
Hi mut2ley,
Thanks for getting back to me. I'm glad the community give you advice on how to log into the router, that is great.
I appreciate the router information you posted. Even though these are showing as fine, when I just checked your line, the Modem SNR for both upstream and downstream are getting low. I would like another engineer to check this over for you. I appreciate you have just had a visit, however it does need to be looked into. I've sent you a PM (purple envelope icon, right corner) with some details for you to confirm please.
Speak soon
Sam
