Bablefish2
Message 1 of 8
wifi Signal keeps dropping out
I have a superhub 2 and the wifi signal keeps dropping out.
I can see the signal going from full to nothing.  1 min its a full strong signal -45 dBm, next there is no signal at all. and it just keeps coming and going.
I also have a second wifi extender which has a wired connection to the hub, this signal remains constant throughout.
There are only 3 wifi signals that I receive, my 2 networks and a neighbours, there is no interference.
I have tried resetting the hub, changing the channel and also moving the wifi on the router to the secondary channel.
VM have apparently run a test and could not find anything wrong, they say its because I too many devices connected ( about 20), this is just nonsense.
Does anyone have any ideas why the router keeps dropping the wifi signal
  • 7.25K
  • 756
  • 1.13K
Legend
Message 2 of 8
Re: wifi Signal keeps dropping out
Is the connection on a device connected by ethernet cable dropping at the same time?  It is important to know that because if it isn't it suggests there may be a problem with the SH2 wifi components rather than with your network connection.  If they both go down it could still be a faulty Hub but also could be a fault on your connection.
Bablefish2
Message 3 of 8
it is only the wifi from the router that is dropping.
anything connected by ethernet appears to be fine.
I also have a wireless access point, in another part of the house which is connected by ethernet.  I am now having to use that as the signal from the hub is so unreliable.
  • 1.71K
  • 94
  • 316
Super solver
Message 4 of 8
@Bablefish2 wrote:
<snip>
I suspect there may be an element of truth in that statement.  VM Hubs are built to a cost and with +20 devices, you could be overloading the router.  If you temporally turn off some of the devices,  does it help ?
If so, you should invest in a good Router and just run the Hub in Modem mode.
  • 7.25K
  • 756
  • 1.13K
Legend
Message 5 of 8
Good advice from Adduxi - put it in modem mode and get a good wifi router next to the Hub.
Bablefish2
Message 6 of 8
any recommendations for a good wifi router..........
  • 7.25K
  • 756
  • 1.13K
Legend
Message 7 of 8
Depends on your budget and what additional features you want in the router?  Just make sure its a cable router and not ADSL.
Bablefish2
Message 8 of 8
Eventually Virgin Tech has replaced the router and everything is fine
