using tp link ac1750 as access point with hub 3
hi there I struggle to get a signal down stairs as we stay in high flats and all brick walls my question is i want to buy the ac 1750 router and use as access point to get signal down the stairs what speeds would I get I'm on 500mbps and have boosters but they aren't great
  • 24.4K
  • 1.4K
  • 3.1K
Re: using tp link ac1750 as access point with hub 3
Who knows - it depends on your environment etc. that effects the wifi.
You won't know until you buy it and set it up
it's because I have brick walls and the farthest away room can't get a signal it's really bad I have seen a YouTube video specifically for ac 1750 for virgin router so I'll give it a try
