  • 5
lilyC
Message 1 of 10
using data but connected to wifi??
Hello everyone, I could really use some help as I'm a bit of a technophobe!
My daughter is managing to use up her data allowances every month. She is also hitting her spending cap each month. I was concerned about this as it is unusual for her, so topped up the cap by an extra 3 pounds last night when she was in bed. By 9.00 this morning she had used it up but not been out of the house and was looking at the internet through wifi at home.
I don't understand how she is using data up when browsing on wifi. Could anyone clarify this for me before I go mad!! she had not sent any picture messages etc, she was literally browsing some of her apps inc whatsapp and maybe listening to a bit of music
Many thanks in advance x
  • 26.32K
  • 1.12K
  • 4.34K
Message 2 of 10
Re: using data but connected to wifi??
yu can check the apps using data in the settings on the phone
Click to learn more about VIP
Use Kudos to say thanks
  • 5
lilyC
Message 3 of 10
can you? could you tell me where to look to find this? many thanks for your helpx
  • 26.32K
  • 1.12K
  • 4.34K
Message 4 of 10
Andoird or iphone?
  • 5
lilyC
Message 5 of 10
its a samsung galaxy 7 edge . I had a look and it does say certain apps like google play and utube use data, but what Im not understanding is why they are using so much when t home, connected to wifi? she is running out of 8GB a month plus extra? it seems a lot
  • 5
lilyC
Message 6 of 10
that should have said Galaxy S7 Edge
  • 26.32K
  • 1.12K
  • 4.34K
Message 7 of 10
normally ion settings data usage.
If the wifi is dropping out the mobile data will take over. If she moves out of range.
It should tell you what apps are using the data.
You might want to turn off mobile data when at home if the wifi is dropping out
  • 4.7K
  • 319
  • 789
Roger_Gooner
Superstar
Message 8 of 10
I have a Samsung Galaxy phone and have mobile data disabled at home (Settings > Connections > Data usage > Mobile data). Your daughter should do the same. She should check her WiFi speed with speedtest.net.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 5
lilyC
Message 9 of 10
Hiya, thanks for reply. Does it automatically revert back to data outside and back to wifi when she comes home or would you have to do it manually each time? I will have a look
  • 4.7K
  • 319
  • 789
Roger_Gooner
Superstar
Message 10 of 10
When Mobile data is disabled it can only be manually enabled. This is exactly what I want as a WiFi failure becomes noticeable.
