phils3
Message 1 of 5
saying Ethernet cable is unplugged checked connection all connections ok swapped the cable same result
Ethernet cable unplugged is the error message checked connections all ok even tried another cable same result. Have reset several times all to no avail same message currently running it in modem mode its ok been like this for a week now seems a few have the same problem is there any answer or do I need a call out?
  • 2.49K
  • 119
  • 329
jpeg1
Problem sorter
Message 2 of 5
Re: saying Ethernet cable is unplugged checked connection all connections ok swapped the cable same resu
Have you plugged the other end of the cable into a different device?
phils3
Message 3 of 5
I had not thanks for the advice its now working so thankyou
  • 2.49K
  • 119
  • 329
jpeg1
Problem sorter
Message 4 of 5
Glad you got it sorted.
  • 725
  • 21
  • 40
Message 5 of 5
Re: saying Ethernet cable is unplugged checked connection all connections ok swapped the cable sa...
Hi phil3, thank you for letting us know this issue has now been resolved.
Please let us know if we can assist in the future.
Nat
