on 01-08-2021 17:18
my robovac device will not connect to wifi. it used to connect, went off and I'm unable to reconnect.
I've reset router, reset robovac, tried everything else several times.
the app for the vac can see it tries to connect but spinning circle all the time.
I've tried another vac as thought it was the problem but it won't connect either. I've got a hub 3. four devices are connected so not overly used.
any help?
on 01-08-2021 18:21
Can your Robovac connect to other wireless routers?
Can other wireless devices (that you're not already using), connect to your router? Friends or relatives' tablets or phones, for example.
