on 21-02-2022 22:23
hi i have had the dreaded red led on my router for some days now, it is NOT overheating
it checks out ok but it would appear to be failing and i cannot have that happen.
on 21-02-2022 22:52
Please do a pin hole reset. If it persists after than the hub will need replacing. Please report back.
on 22-02-2022 07:36
have just done a pinhole reset and its come back on but still with red led, looks like I do need a replacement, asap as I cannot be without broadband.
regards Colin
on 22-02-2022 08:55
Hi colinmcs,
Thanks for posting and welcome to the community!
From checking our service I can't see any readings that would attribute to the red light.
Has the factory reset benefitte your service?
on 22-02-2022 08:58
@Kain_W wrote:Hi colinmcs,
sorry and with respect a red light on a hub3 means the hub needs replacing - levels and tests may say its ok but its showing as overheating -
on 22-02-2022 09:01
Thanks for the response Colin,
Also thanks for performing the reset.
I've dropped you a PM so we can arrange a replacement for you.
on 23-02-2022 10:22
Thanks for your cooperation over PM colinmcs,
The appointment is now booked in for yourself.
If you do need to reschedule/cancel at any point then you can do so via our link to MyVM here.
Thanks and take care,
