on 14-11-2022 16:32
Noticed a solid red base light on my hub3 router since last week, but fortunately the internet is working fine. I've done the pinhole reset and switch it off at bedtime etc. having read about the possibility of reheating. The router has been in the same position for a year. Having read other posts it sounds as if it needs replacing.
14-11-2022 16:50 - edited 14-11-2022 16:50
Hi @bri99
Thanks for posting on our community forum and a big warm welcome with this being your first post.
Sorry to hear about the issues with your broadband, I'll drop you a private message now to confirm some more details and investigate further - please keep an eye on your inbox for a message from myself.
on 14-11-2022 18:39
Hi @bri99
Thanks for confirming those details via Private Message
Please do be sure to keep us updated once the visit has concluded and thank you for your patience 🙂
on 15-11-2022 12:13
Engineer has just connected a new hub3 router as it was faulty. Apparently you no longer have a white base light on these hubs, it's orange instead. Very pleased with the prompt service following my initial post.
on 17-11-2022 17:34
Hi bri99, thanks for the message and welcome back to the forums.
I am happy to hear that the engineer has been able to get things resolved for you and that the service is now as it should be.
If you have any further questions please let us know, otherwise have a good night.
Kind regards
Chris.
