14-04-2022 16:01 - edited 14-04-2022 16:02
when i try to enable it and click apply changes the box is still empty?
on 14-04-2022 16:32
which hub is it?
I can't see anything obvious - just buggy operation of the VM Hubs?
get your own router with hub in modem mode - that's your best bet....
on 14-04-2022 16:47
super hub 4
on 18-04-2022 10:41
Hey @OTJF,
Welcome to the community and thanks for taking the time to post your issue on the forums.
Have you been able to resolve the issues since you last posted or is it still an ongoing issue?
Regards,
Steven_L
on 18-04-2022 18:27
still a ongoing issue
on 18-04-2022 22:48
I would assume you need to tick the <enabled> box and then <apply changes>. I run in modem mode so I have no knowledge of what you do for port setting in the VM hubs.
on 18-04-2022 22:50
on 19-04-2022 08:28
Try a factory reset (you will need to reapply any changes made previously including existing port forwarding rules - if they are not set up again by UPnP).
on 21-04-2022 09:30
Hi @OTJF, thanks for your post although I'm sorry to hear you're having issues setting up port forwarding.
As @Tudor has mentioned, if you tick the box where it says "enabled" and then "apply changes" it should once you've refreshed the settings page remain Enabled.
I do believe that this is what you've already done though, but please let us know once you've performed the factory reset (thanks @g0akc for this tip) and tried this again if you're having the same issue still.
Many thanks
