  • 3.38K
  • 191
  • 548
chenks
Wise owl
port forwarding
so i've migrated over to viring and using the virgin hub.
i have a plex server on my local network which required port 32400 to be open for external access.
I have opened the TCP port 32400 on the hub and set it to forward to the local IP address of the plex server (which has a static local ip set by DHCP).
however, even though the port is open (and tested as open via one of the many port checking website), remote plex still can't get thru to it.
is there something else i need to check on the hub?
this is usually a very easy process and opening the port on every other router i've used has resulted in it working straight away.
  • 3.38K
  • 191
  • 548
chenks
Wise owl
Re: port forwarding
it's now working.
i guess there was a delay in it propagating.
