on 19-08-2021 16:34
All my devices are working fine but if I go to connected devices on the Hub 3 menu
my pc is not showing.
on 19-08-2021 16:58
on 19-08-2021 17:03
Thanks for the reply. Yes it is connected and working ok. Just not showing
on 19-08-2021 22:12
so, could be gremlins in the hub firmware.. not beyond the realms of possibility, even though it's a pretty basic funciton.
how is the pc connected to the hub? wifi, via another device (e.g. powerline adapter or something?) or ethernet?
can you confirm that the ip address of your pc - is it 192.168.0.x (where x is a number between 2 and 254)..
on 20-08-2021 09:25
Yes my ip address is as you say.
on 20-08-2021 10:45
Sorry connected through powerline.
on 20-08-2021 12:34
@nobley wrote:Sorry connected through powerline.
Well, the connection is working.. in order for your pc to talk to teh hub (and vice-versa) they must know each-others MAC address (the hardware address of the network interface).
This means that, irrespective of your hubs ability to render this in the GUI, it knows that your PC (192.168.0.55 for example) has a hardware address of xx:xy:xx:xx:xy:xz. So it could just be a bug that's preventing your pc's details from showing in the hub GUI
The alternative theory, given that you're running powerline adapters, is that somehow your PC has picked up an address from a neighbour.. this is possible, but i'd expect that if you'd bridged networks with a neighbour and you're both using the same subnet (192.168.0) that you'd be having all sorts of weird and wonderful problems on the network..
on 20-08-2021 14:53
Thanks for the reply Sophist.
The other pc in the house and the tv, both connected through powerlines, are showing as well as all the wi fi connected devices.
As you said if I was using a shared network I would know about it.
It's not important just annoying.
on 20-08-2021 15:07
Don't know why but all my devices are showing in the Hub3 menu.
