on 07-06-2023 08:27
Recently in the last month or two started getting randomly degraded network performance. I've restarted everything and reseated all the cables, but its persisted with errors on channel 19 and 13
1 | 330750000 | 8.3 | 38 | 256 qam | 25 |
2 | 234750000 | 7.1 | 38 | 256 qam | 13 |
3 | 242750000 | 6.4 | 38 | 256 qam | 14 |
4 | 250750000 | 7.9 | 38 | 256 qam | 15 |
5 | 258750000 | 8.5 | 38 | 256 qam | 16 |
6 | 266750000 | 8.6 | 38 | 256 qam | 17 |
7 | 274750000 | 8.5 | 38 | 256 qam | 18 |
8 | 282750000 | 8.4 | 38 | 256 qam | 19 |
9 | 290750000 | 8.5 | 38 | 256 qam | 20 |
10 | 298750000 | 8.3 | 38 | 256 qam | 21 |
11 | 306750000 | 8.5 | 38 | 256 qam | 22 |
12 | 314750000 | 8.1 | 38 | 256 qam | 23 |
13 | 322750000 | 8.4 | 38 | 256 qam | 24 |
14 | 338750000 | 8.4 | 38 | 256 qam | 26 |
15 | 346750000 | 7.5 | 38 | 256 qam | 27 |
16 | 354750000 | 6.1 | 38 | 256 qam | 28 |
17 | 362750000 | 5.9 | 38 | 256 qam | 29 |
18 | 370750000 | 6 | 38 | 256 qam | 30 |
19 | 378750000 | 6.4 | 38 | 256 qam | 31 |
20 | 386750000 | 6 | 38 | 256 qam | 32 |
21 | 394750000 | 6.4 | 38 | 256 qam | 33 |
22 | 402750000 | 5.9 | 38 | 256 qam | 34 |
23 | 410750000 | 6 | 38 | 256 qam | 35 |
24 | 418750000 | 5.5 | 38 | 256 qam | 36 |
1 | Locked | 38.9 | 416 | 0 |
2 | Locked | 38.9 | 1677 | 0 |
3 | Locked | 38.9 | 2520 | 0 |
4 | Locked | 38.6 | 1057 | 0 |
5 | Locked | 38.9 | 533 | 0 |
6 | Locked | 38.9 | 532 | 0 |
7 | Locked | 38.9 | 640 | 0 |
8 | Locked | 38.6 | 873 | 0 |
9 | Locked | 38.6 | 452 | 0 |
10 | Locked | 38.6 | 505 | 0 |
11 | Locked | 38.9 | 347 | 0 |
12 | Locked | 38.9 | 518 | 0 |
13 | Locked | 38.9 | 412 | 0 |
14 | Locked | 38.9 | 376 | 0 |
15 | Locked | 38.6 | 693 | 0 |
16 | Locked | 38.9 | 1999 | 0 |
17 | Locked | 38.6 | 2353 | 0 |
18 | Locked | 38.9 | 1607 | 0 |
19 | Locked | 38.9 | 1889 | 1307 |
20 | Locked | 38.9 | 1948 | 0 |
21 | Locked | 38.6 | 2100 | 13 |
22 | Locked | 38.6 | 2555 | 0 |
23 | Locked | 38.6 | 2285 | 0 |
24 | Locked | 38.9 | 2717 | 0 |
on 09-06-2023 12:29
Hi @monadproxy 👋 Thank you for your post 😀
We're sorry to hear about the problems you're experiencing 😔
We've had a look on our systems and it appears you're being impacted by a power issue.
In order to look into this for you further, we'll send you a private message on here.
Look out for the envelope in the top right-hand corner. If you're on a portable device with a smaller screen, click on the icon in the top right-hand corner and select "messages" from the additional menu options.
Regards,
Daniel
