Nomadscot
only can access wireless connection on guest network (super hub 3)
I have just set up a Guest Network on my Superhub 3, but it occurs to me that guests will be able to easily connect to my private network by the simple expedient of connecting an ethernet cable to the router.
is this so? If so, how can I protect my private network?
  • 11.78K
  • 1.08K
  • 2.55K
griffin
Re: only can access wireless connection on guest network (super hub 3)
Don't allow people to connect directly to the Hub.
If people have free access to the hub, there is not much you can do, as the Hub or router can easily be reset to factory defaults.
One way would be to purchase a third party router for guests only, which can be set up on a different subnet.
