on 06-05-2022 07:47
I have been having trouble both with wifi and lan connections, its been happening for approx 12 months now, i had an engineer out out and he did some tests, he then fitted some thing to the black cable, and told me it was fixed, for a while it seemed ok, but over the last month or so it has gotten worse, ive been checking the logs and the same ones appear regularly, its my understanding from reading the posts in this forum there is a problem with the cpu on the mb. here are my logs from today.
06/05/2022 06:17:26 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/05/2022 16:12:29 | notice | NOTICE ATOM is restarted due to Kernel/oops panic as part of Self Healing Mechanism ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/05/2022 14:26:39 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/05/2022 07:58:35 | notice | NOTICE ATOM is restarted due to Kernel/oops panic as part of Self Healing Mechanism ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:01:40 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/05/2022 06:44:56 | notice | NOTICE ATOM is restarted due to Kernel/oops panic as part of Self Healing Mechanism ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/05/2022 06:44:4 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
03/05/2022 23:56:23 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
03/05/2022 15:29:23 | notice | NOTICE ATOM is restarted due to Kernel/oops panic as part of Self Healing Mechanism ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
03/05/2022 10:42:13 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:01:41 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
02/05/2022 03:48:22 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
02/05/2022 01:41:46 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
30/04/2022 15:15:21 | notice | NOTICE ATOM is restarted due to Kernel/oops panic as part of Self Healing Mechanism ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:01:44 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
30/04/2022 11:52:5 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
29/04/2022 08:50:4 | notice | NOTICE ATOM is restarted due to Kernel/oops panic as part of Self Healing Mechanism ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
27/04/2022 17:03:9 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/04/2022 21:04:44 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/04/2022 03:21:28 | notice | SW download Successful - Via NMS |
I also keep getting a message from the hub when trying to log in saying that some one is already logged in and only one session at at time, i have to restart the hub and wait to log in.
Answered! Go to Answer
on 18-05-2022 12:05
Sorry to hear you're still having trouble with this. Have the previous technicians ever replaced your equipment directly? Or has it always been the cabling?
Were you able to setup a Broadband Quality Monitor (BQM)? If so, are you able to provide a screenshot or direct link so we can diagnose this further? If you haven't, you can setup a Broadband Quality Monitor up here: https://www.thinkbroadband.com/broadband/monitoring/quality
on 18-05-2022 20:21
on 20-05-2022 05:16
on 22-05-2022 13:50
Hi tige,
Thank you for getting back to us.
I am very sorry for the issues you have been experiencing.
I have ran some checks from our side and can confirm there are no errors being reported and your Hub stats appear to be running within specification.
You have mentioned that your Hub is showing signs of overheating. Can you please expand on this?
Is the equipment displaying a red light, hot to touch or making any unusual loud noises? If so can you please confirm if the Hub is in an open space?
Let us know and we will be happy to assist further.
on 22-05-2022 21:32
on 24-05-2022 18:21
on 25-05-2022 08:45
on 27-05-2022 09:09
Good Morning @tige, thanks for the update and I'm sorry to see the issue with the broadband services are still ongoing.
I've been able to look into the local area and can see that an outage is currently flagged and is due to be resolved by 17:00 today.
Do please check back in with us beyond this time frame.
Kindest regards,
David_Bn
on 09-06-2022 09:49
on 12-06-2022 10:12
Hi tige,
Thank you for getting back to us and we are very sorry you feel this way.
I have taken a look from our side and on the live report, everything does appear to be running within specification with no error reported.
The system has detected that you may benefit from adding WiFi Pods to your service to improve WiFi within the property. More information on these can be found here
How have things been since your last post to us?
