  • 8
Message 1 of 10
hub3 problem
hi
i want to roll back my hub3 to a router/modem but when i input s/n of hub i get not authorised s/n is not correct.
I am certain it has been put in correctly
any thoughts ?
  • 115
  • 14
  • 25
Up to speed
Message 2 of 10
Re: hub3 problem
Check you are using the number printed on the bottom of the hub and that you aren't confusing it with the wifi password.
M350 over FTTP
  • 11.57K
  • 898
  • 1.48K
Message 3 of 10
Re: hub3 problem
To access the Hub Settings you don't need the Serial Number, you need the Settings Password.
Note: In modem Mode you need to use an ethernet cable connected device to connect to the Hub.
Hub-3-Password
Mike Robinson
Retired Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 8
Message 4 of 10
Re: hub3 problem
Tried to get access but got following reply
401 Unauthorized
Access to this resource is denied, your client has not supplied the correct authentication.
We can help you reset your router's admin password. You need your router's serial number, which can be found on the router label. Enter your router's serial number in the field and click the Continue button.
Enter the router's Serial Number:
(You can find it on the router product label.
  • 24.46K
  • 1.4K
  • 3.11K
Message 5 of 10
Re: hub3 problem
That doesn't sound right at all..
Have you rebooted the hub then tried?
  • 8
Message 6 of 10
Re: hub3 problem
yes tried many solutions wonder if Virgin has blocked me
  • 24.46K
  • 1.4K
  • 3.11K
Message 7 of 10
Re: hub3 problem
Why would they block you?
If the password isn't working then factory reset the hub by doing a 60 second pinhole reset
  • 39
  • 6
Message 8 of 10
Re: hub3 problem
have you tried the reset button on the back of the hub?
Hope this helps.
  • 8
Message 9 of 10
Re: hub3 problem
would the 60 second reset take it back to router and modem mode without any further adjustment\.
and to complete a pinhole reset do I disconnect the hub
  • 24.46K
  • 1.4K
  • 3.11K
Message 10 of 10
Re: hub3 problem
The reset will take it back to factory defaults which is router mode.
All the passwords and wifi SSID's will be as per the sticker on the bottom of the hub.
Leave the power etc. on and just hold the button in for 60 then let go.
