  • 12
laneysnr
Message 1 of 10
hub keeps droping connection
my hub keeps loosing conection or time outs it has been going on for quite a while now and i am getting fed up with it i am connecting with both wifi and wired.its the wired i keep geting time outs
here is one from today.i have rebooted the box on many ocations even tried restoring to factory settings but to no avail.
Date
Time
Error Number
Error Description
17/09/2018
14:14:47 GMT
66050310
Auth Success - Web login successful.
17/09/2018
14:09:13 GMT
66050310
17/09/2018
10:28:55 GMT
68010302
DHCP WAN IP - 82.4.*********
17/09/2018
10:27:55 GMT
68000407
TOD established
Time Not Established
84000510
Downstream Locked Successfully
17/09/2018
06:03:42 GMT
84020200
Lost MDD Timeout
17/09/2018
06:03:42 GMT
84020200
Lost MDD Timeout
17/09/2018
06:03:42 GMT
84020200
Lost MDD Timeout
17/09/2018
06:03:42 GMT
84020200
Lost MDD Timeout
17/09/2018
06:03:42 GMT
84020200
Lost MDD Timeout
17/09/2018
06:03:41 GMT
84020200
Lost MDD Timeout
17/09/2018
06:03:41 GMT
84020200
Lost MDD Timeout
17/09/2018
06:03:41 GMT
84020200
Lost MDD Timeout
17/09/2018
06:03:37 GMT
84000500
SYNC Timing Synchronization failure - Loss of Sync
17/09/2018
06:03:36 GMT
84000500
15/09/2018
19:05:33 GMT
84020200
Lost MDD Timeout
15/09/2018
19:05:33 GMT
84020200
Lost MDD Timeout
15/09/2018
19:05:33 GMT
84020200
Lost MDD Timeout
15/09/2018
19:05:33 GMT
84020200
Lost MDD Timeout
15/09/2018
19:05:32 GMT
84020200
Lost MDD
[MOD EDIT: For your security personal and private information has been removed from this post. Please review the Forum Guidelines]
  • 19.08K
  • 1.67K
  • 4.18K
Message 2 of 10
Re: hub keeps droping connection
could you post the downstream and upstream stats
If someone's helped you out say thanks by clicking on the thumbs up on kudos. If someone's solved your problem, why not mark their message as an Accepted Solution, but only do this once issue has been resolved.
  • 12
laneysnr
Message 3 of 10
are these what you mean
downstream
Lock Status Channel ID Frequency Modulation Rx Power RxMER Pre RS Errors Post RS Errors
Locked1138750000 Hz256 QAM2.3 dBmV 36.8 dB72873859
Locked2146750000 Hz256 QAM1.9 dBmV 36.8 dB66754174
Locked3154750000 Hz256 QAM1.0 dBmV 36.4 dB69385812
Locked4162750000 Hz256 QAM0.3 dBmV 36.4 dB73125510
Locked5170750000 Hz256 QAM-0.3 dBmV 36.2 dB60103268
Locked6178750000 Hz256 QAM-1.6 dBmV 36.2 dB65893763
Locked7186750000 Hz256 QAM-2.2 dBmV 36.0 dB69214137
Locked8194750000 Hz256 QAM-2.8 dBmV 35.6 dB72284234
Upstream ChannelsLock Status Channel ID Frequency Modulation Tx Power Mode Channel Bandwidth Symbol Rate
Locked239400000 HzATDMA47.3 dBmV16QAM6400000 Hz5120 Ksym/sec
Locked332600000 HzATDMA46.3 dBmV16QAM6400000 Hz5120 Ksym/sec
Locked146200000 HzATDMA48.0 dBmV16QAM6400000 Hz5120 Ksym/sec
Locked425800000 HzATDMA45.5 dBmV16QAM6400000 Hz5120 Ksym/sec
  • 19.08K
  • 1.67K
  • 4.18K
Message 4 of 10
those are all showing fine, so more than likely issue is external would be close a week for the forum staff to take a look.
  • 12
laneysnr
Message 5 of 10
maybe something else as we are getting channels dropping signals. i mean the channel goes off after a few seconds to minutes it comes back on.might need new cable outside
  • 10.32K
  • 280
  • 591
Forum Team (Retired) Emma_E
Message 6 of 10
Hi laneysnr,
Thanks for getting in touch. I am sorry to see you have had trouble with your connection.
I have taken a look and things seem to be ok from this side. It may help to try the following so we can rule some things out:
Pop the hub into Modem Mode with the computer in Safe Mode with Networking at different times of the day.
Try on separate devices.
Check Ethernet cable. Make sure it is new / up to date. (Cat 5e or above).
Make sure device is capable of agreed speed.
Check wireless card slide.
Take care.
 Emma
  • 12
laneysnr
Message 7 of 10
i have replaced network cables with brand new ones i have new networkcards that can handle 100mbs i have also noticed within the last few days that the wirless has dropped out and after restarting the modem it came back on also i am getting tv channels losing there signals. so i think it might be an out side fault
  • 11.7K
  • 347
  • 678
Forum Team (Retired) Samantha_L
Message 8 of 10
Hi laneysnr,
Thanks for posting back here.
With the broadband connection disconnecting, do you notice any lights change on the router at all? Is the router left on at all times?
I've tried to take a look at the TV service, however it is showing as being offline? Is this the case or is the TV not working at all now?
Speak to you soon
Sam
  • 12
laneysnr
Message 9 of 10
the lights on the router except the updown arrow flashing .the router is left on all the time but i have to turn it off quite often.i have just restored it to factory settings which helps for a short time . the tv is only on late afternoon or evening it is turned off otherwise.
the last couple of times the tv had a problem with no signal was 3rd october 3.50pm. 4th october 4.05pm the was more previously and one after theses dates but i never got to write them down. i dont watch the virgin tv very often as i mainly live up stairs.
  • 9.07K
  • 248
  • 544
Forum Team (Retired) Nat_J
Message 10 of 10
Thanks for updating laneysnr,
I'm very sorry for the trouble experienced.
I'd like to arrange for an engineer to visit.
I've sent you a private message so that we can get this booked in.
Speak soon,
Nat_J
