on 20-08-2022 18:01
im trying to access my hub 5 router settings and whenever i put the password in it keeps saying it's wrong even though i've used my iphone to take an image, copy the text from the image and paste it into the password box
Answered! Go to Answer
on 20-08-2022 18:12
20-08-2022 18:04 - edited 20-08-2022 18:06
Possibly a stupid question, but you are using the right password (I think they are all numbers) rather than the WiFi password/passphrase?
Otherwise it is possible that you have been sent a second hand Hub5 and a previous owner had changed the password and VM didn't factory reset it before sending it to you. Try a full factory reset yourself, ie pin in the reset hole and hold it in for a full 60 seconds and allow the hub to reboot itself.
on 20-08-2022 18:04
on 20-08-2022 18:09
well the password im using has the hub settings link above it and then password under it which has letters and numbers, also im not using the wifi password lol
on 20-08-2022 18:10
ive tried on multiple devices
on 20-08-2022 18:12
on 20-08-2022 18:26
thank you the pinhole reset worked!
20-08-2022 18:32 - edited 20-08-2022 18:33
Second hand Hub then........
or it's a bit flakey, not sure which is worse.
