  • 8
lewishilary
Message 1 of 5
hub 3 wi-fi not working
Have just installed Hub 3. Ethernet connection to PC is O.K.
However, wifi not working after over an hour and a half from install. White light is on at bottom the Hub 3. Password 'saved' under wifi network id. Wifi connected icon at top of phone is in background with question mark.
  • 9.06K
  • 934
  • 1.41K
Message 2 of 5
Re: hub 3 wi-fi not working
How many devices have you tested the wifi connection on? What are they?
Can you see your networks ssid in the phones list of connection options?
Try resetting the phones network connection and restart phone and try and connect again.
  • 8
lewishilary
Message 3 of 5
Someone seems have joined in with info about HD TV etc which is nothing to do with me. We have 2 android phones and 1 Kindle.
  • 9.06K
  • 934
  • 1.41K
Message 4 of 5
Samsung S7's by any chance?
  • 8
lewishilary
Message 5 of 5
I found a very simple way of correcting this problem as follows: press reset for 30 seconds then turn off power for 1 minute. After power has been switched on again, allow 10 minutes for Hub 3 to reboot.
