on 12-08-2021 18:30
Hi i have a hub 3 that is showing red on power light the moden is in free air no other equipment by it. It has been ok until last 4-5 days. i have done power on/off factory reset. It will drop internet connection both wired and wifi. power on/off will eventily get back on line. It is getting worse. Unit is not particularly hot. By adding an ethernet switch the wired connections seem to work better?
Does it require an enginner? Surley just plug in and run.
on 12-08-2021 19:07
Thanks for your post and welcome to the Community Forums , DaveF56,
I've sent you a private message to confirm your account details so we can get an tech sent out.
Cheers,
Corey C
on 12-08-2021 19:12
a 100Mb switch that not 1Gb...
on 14-08-2021 16:15
Hi DaveF56,
Thanks for coming back to the team via Private Message.
We're glad things are all resolved for you now. If you do have any further issues, please pop back and let us know so we can help further.
Take care,
