on 29-08-2022 12:14
Hi all
Will keep this short and sweet
Have hub3 200mb with virgin
Wifi is great get 200mb+ via wifi
When I plug my devices via home plug or ethernet to MacBook I only get 93mb? So nothing higher than 100mb
Have tried rebooting, turning off all the security features tried every port in the router and using cat5e cables (have changed and swapped and still the same).
Don't have a mesh just using the router in normal mode not modem.
This is very annoying and any help would be much appreciated.
Do I need a new router?
on 29-08-2022 14:14
