  • 6
Dbajarcuks
Message 1 of 7
hub 3 issues
My HUB 3 loosing signal every couple minutes. It’s not rebooting just no internet. Is anyone can advice something. I can’t even watch online movie as computer says that not connected to the internet but signal is 99%
  • 5.43K
  • 425
  • 912
Superstar
Message 2 of 7
Re: hub 3 issues
Go into your hub on 192.168.0.1 and post your up/down stream stats and network log.
There are 10 types of people: those who understand binary and those who don't and F people out of 10 who do not understand hexadecimal
  • 6
Dbajarcuks
Message 3 of 7
Re: hub 3 issues
Could You please direct me where to fing up/down stream stats
Network LogDate And Time Error Number Event Description
2018-06-26 16:12:29.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-06-26 16:12:29.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-06-26 16:12:34.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-06-26 16:12:35.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-06-26 16:26:02.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-06-26 16:26:02.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-06-26 16:26:05.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-06-26 16:26:06.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-06-26 16:26:06.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-06-26 16:26:07.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-06-26 16:26:07.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-06-30 13:22:31.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-07-01 10:16:37.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-07-01 11:24:59.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-07-01 12:32:24.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-07-01 12:59:27.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-07-01 14:33:58.0068010400DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;C
  • 6
Dbajarcuks
Message 4 of 7
Re: hub 3 issues
Downstream bonded channelsChannel Frequency(Hz) Power(dBmV) SNR(dB) Modulation Channel ID
14582500000.238.6256 qam7
2594250000038.6256 qam24
35862500000.238.6256 qam23
4578250000038.9256 qam22
5570250000038.9256 qam21
6562250000038.6256 qam20
7554250000038.9256 qam19
8546250000038.6256 qam18
95382500000.238.9256 qam17
105302500000.238.6256 qam16
11522250000038.6256 qam15
12514250000038.6256 qam14
13506250000038.9256 qam13
144982500000.238.9256 qam12
154902500000.538.9256 qam11
164822500000.538.9256 qam10
174742500000.538.9256 qam9
184662500000.238.6256 qam8
194502500000.238.6256 qam6
204422500000.438.6256 qam5
214342500000.238.6256 qam4
224262500000.238.9256 qam3
23418250000038.6256 qam2
24410250000-0.238.9256 qam1
  • 6
Dbajarcuks
Message 5 of 7
Re: hub 3 issues
Upstream bonded channelsChannel IDFrequency(Hz)ModePower
(dBmV)ModulationChannel Bandwidth(Hz)Symbol Rate (ksps)946200000ATDMA42.316 qam640000051201132600000ATDMA42.316 qam64000005120
  • 18.93K
  • 1.65K
  • 4.14K
Message 6 of 7
Re: hub 3 issues
downstream is showing fine, can you post upstream
  • 6
Dbajarcuks
Message 7 of 7
Re: hub 3 issues
Channel ID Frequency(Hz) Mode Power(dBmV) Modulation Channel Bandwidth(Hz) Symbol Rate (ksps)
