jul17
Settling in
green wifi light constantly flashing on Hub 3
This has been happening for the last 3 weeks - switching off and on makes it go away for a few hours - constant flashing is really annoying and it didn't used to do this!  Tech Support just told me everyone's does this now since a recent change something to do with searching for networks and stopping viruses - so it's not a fault !!  Posts here about this are old and talk about it being a fault - can somebody verify this latest information please?
  • 160
  • 7
  • 7
Re: green wifi light constantly flashing on Hub 3
Hi Jul17,
This will depend on the type of hub that you have, this may be coming from the WPS signal. Is this affecting your service?
Cheers,
Corey
