09-09-2021 11:31 - edited 09-09-2021 11:33
I've been having issues with packet loss and interrupted connections over the past week, I've scoured the forums and tried a lot of troubleshooting with my router but nothing seems to have workedso far.
I set up the BQM thinkbroadband graph last night, here are the results:
The big red bar was me ressetting my router completely
edit: some info i should have provided
my router is the hub3 and this problem occurs both over ethernet and wifi
on 09-09-2021 11:38
Here's the router logs as well:
Acquired Downstream Channel (Hz) | 387000000 | Locked |
Ranged Upstream Channel (Hz) | 53699993 | Locked |
Provisioning State | Online |
1 | 387000000 | 5.1 | 40 | 256 qam | 32 |
2 | 267000000 | 5 | 40 | 256 qam | 17 |
3 | 275000000 | 4.8 | 40 | 256 qam | 18 |
4 | 283000000 | 4.9 | 40 | 256 qam | 19 |
5 | 291000000 | 4.5 | 40 | 256 qam | 20 |
6 | 299000000 | 4.4 | 38 | 256 qam | 21 |
7 | 307000000 | 4.6 | 40 | 256 qam | 22 |
8 | 315000000 | 4.8 | 40 | 256 qam | 23 |
9 | 323000000 | 4.5 | 38 | 256 qam | 24 |
10 | 331000000 | 4.5 | 38 | 256 qam | 25 |
11 | 339000000 | 5 | 38 | 256 qam | 26 |
12 | 347000000 | 4.8 | 40 | 256 qam | 27 |
13 | 355000000 | 4.6 | 38 | 256 qam | 28 |
14 | 363000000 | 5.1 | 38 | 256 qam | 29 |
15 | 371000000 | 5.6 | 40 | 256 qam | 30 |
16 | 379000000 | 5.4 | 40 | 256 qam | 31 |
17 | 395000000 | 5.5 | 40 | 256 qam | 33 |
18 | 403000000 | 5.3 | 40 | 256 qam | 34 |
19 | 411000000 | 5 | 38 | 256 qam | 35 |
20 | 419000000 | 5 | 38 | 256 qam | 36 |
21 | 427000000 | 5.1 | 40 | 256 qam | 37 |
22 | 435000000 | 4.5 | 40 | 256 qam | 38 |
23 | 443000000 | 4.5 | 38 | 256 qam | 39 |
24 | 451000000 | 5 | 38 | 256 qam | 40 |
1 | Locked | 40.3 | 4 | 0 |
2 | Locked | 40.9 | 6 | 0 |
3 | Locked | 40.3 | 4 | 0 |
4 | Locked | 40.3 | 6 | 0 |
5 | Locked | 40.3 | 5 | 0 |
6 | Locked | 38.9 | 6 | 0 |
7 | Locked | 40.3 | 6 | 0 |
8 | Locked | 40.3 | 6 | 0 |
9 | Locked | 38.9 | 12 | 0 |
10 | Locked | 38.9 | 7 | 0 |
11 | Locked | 38.9 | 12 | 0 |
12 | Locked | 40.3 | 6 | 0 |
13 | Locked | 38.9 | 8 | 0 |
14 | Locked | 38.9 | 6 | 0 |
15 | Locked | 40.3 | 8 | 0 |
16 | Locked | 40.3 | 5 | 0 |
17 | Locked | 40.3 | 5 | 0 |
18 | Locked | 40.3 | 9 | 0 |
19 | Locked | 38.9 | 6 | 0 |
20 | Locked | 38.9 | 8 | 0 |
21 | Locked | 40.3 | 4 | 0 |
22 | Locked | 40.9 | 19 | 0 |
23 | Locked | 38.9 | 4 | 0 |
24 | Locked | 38.9 | 0 | 0 |
1 | 53699993 | 44 | 5120 | 64 qam | 6 |
2 | 39399996 | 44 | 5120 | 64 qam | 8 |
3 | 46200004 | 44 | 5120 | 64 qam | 7 |
4 | 60300000 | 44 | 5120 | 64 qam | 5 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
09-09-2021 11:38 - edited 09-09-2021 11:47
08/09/2021 06:49:17 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/09/2021 18:32:23 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/09/2021 06:09:48 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/09/2021 16:10:33 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/09/2021 02:52:13 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/09/2021 02:02:4 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/09/2021 02:02:4 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/09/2021 04:56:42 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
31/08/2021 04:13:37 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
31/08/2021 04:13:37 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/08/2021 10:48:39 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
27/08/2021 16:13:37 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
27/08/2021 16:13:37 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/08/2021 22:40:2 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/08/2021 04:13:37 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/08/2021 04:13:37 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/08/2021 21:05:2 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/08/2021 16:13:36 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/08/2021 16:13:36 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/08/2021 09:18:3 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
edit: I've recently seen that alot of this seems to be happening around my area, Wigan. The specific hostname i connect to is: cpc111179-wiga15-2-0-cust989.18-3.cable.virginm.net
on 09-09-2021 14:07
on 13-09-2021 10:21
Hello toby995
Thanks for your post and BQM
Sorry this has happened and you have had to raise in on our Forums
Would you be able to confirm the questions asked on the above post please
Gareth_L
