on 29-09-2022 17:22
i now have a hub 4 and cannot connect my firestick or my printer , i have spoken to numerous virgin agents and done the whole reset or/and restart the hub umpteen times but still nothing , yet when i had the hub 3 no problems whatsoever
Answered! Go to Answer
on 29-09-2022 18:03
Go into settings on the hub, 192.168.0.1 it’s in there.
on 29-09-2022 17:32
Turn off the 5Ghz WiFi, connect the devices. Once done turn the 5Ghz back on. This may work.
on 29-09-2022 17:40
how do i do that
on 29-09-2022 18:03
on 29-09-2022 19:16
At the risk of sounding stupid I can't find what you posted ,appreciate any more help
on 29-09-2022 19:35
Tried what you said , no change , my firestick works in other places ,
on 02-10-2022 12:44
Hi fitzybhoy,
Thanks for using the forums to get this issue with your broadband looked into, I am sorry if this has been causing some frustration. I would be more than happy to look into this for you.
I understand your Firestick and Printer are having issues, can I ask if these who devices are in the same room?
Does your handset also struggle to connect whilst in that room?
Megan_L
