@legacy1 wrote:
Energy-Efficient Ethernet or EEE on the hub is likely the reason so that transmission power is reduced which the hub may force.
My theory is cross talk at the ports......but yours is equally valid.
@jbrennand wrote:
@Kippies wrote:
I was only right cos I had the same issue myself LOL.
Although it is TOTALLY unofficial, HUB3 likes CAT6 cables, not 5E. Ive tested that across multiple setups and same results. Most CAT5E cables dont work well, my guess is the additional shielding specced for CAT6 is the charm.
That's interesting Kippies. In your experimentation what do you mean by "dont work well"? Just dont work? Attenuate speeds? Fluctuate speeds? Cause drop outs ? Summat else?
Also, how frequently were the issues arising say in ~10 different 5e cables ?
Although i haven't tested hundreds, Id say 50/50 as to which 5E cables gave issues.
MOSTLY the issues seem to be related to speed.
Notable the issue seems worse worse when there is a source of RF noise nearby. As for one connected inline I wouldn't think of using anything other than CAT6 to connect HUB to powerlines for example. Switches seem fine, and oddly cable run doesn't seem to be an issue so thats why I came to my conclusion rather than Legacys (no disrespect intended)
CAVEAT This is all through individual testing, varying cables and other network gear inline. Mostly my concern is throughput (read speed for most) as I move a lot of large files round the place. Even with the worst results of throughput I didn't notice any dropouts, and TBF, MOST stuff is unaffected. Streaming works fine, but I only use 1080p- judging by throughput a wired 5E is still going to be fine for 4K bandwidths if you are streaming to a media device.
Obviously as we are talking about pure bandwidth, speed-test results will be affected. So unless you use a lot of high bandwidth stuff, speed-test is where you will see the issue. Restricting bandwidth to circa 10/100 speeds isn't going to affect browsing etc. So as a rule of thumb if ought else is fine but speed tests, suspect the cable spec, if other issues arise its more likely something else.
Click to learn more about VIP
Use Kudos to say thanks
