on 17-09-2021 13:45
Hi, I'm getting disconnected from remote systems several times each day, using a wired connection into hub 3.0
network speed can vary wildly, should be 200, but its often below 10 for hours though speed seems to be a bit better recently.
Is there anything in the following logs that would indicate a problem cause?
I have an old Netgear router that I could use with the Hub3 in modem mode. Looking at the number of posts on here with people reporting remote access problems I wonder if I might as well go straight to that? Does anyone ever get these type of problems resolved?
17/09/2021 11:49:10 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2021 08:24:55 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/09/2021 13:56:46 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/09/2021 13:32:58 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/09/2021 21:07:8 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/09/2021 15:05:44 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/09/2021 10:04:47 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/09/2021 08:57:11 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/09/2021 20:57:0 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/09/2021 11:37:31 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/09/2021 11:24:28 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1 235000000 -0.5 38 256 qam 13
2 243000000 -0.7 38 256 qam 14
3 251000000 -1 38 256 qam 15
4 259000000 -1.2 38 256 qam 16
5 267000000 -1.2 38 256 qam 17
6 275000000 -1.5 38 256 qam 18
7 283000000 -1.2 38 256 qam 19
8 291000000 -1.2 38 256 qam 20
9 299000000 -1 38 256 qam 21
10 307000000 -1.4 38 256 qam 22
11 315000000 -1.5 38 256 qam 23
12 323000000 -1.9 38 256 qam 24
13 331000000 -2 38 256 qam 25
14 339000000 -2.4 38 256 qam 26
15 347000000 -4.4 38 256 qam 27
16 355000000 -2.7 38 256 qam 28
17 363000000 -2.5 38 256 qam 29
18 371000000 -2.7 38 256 qam 30
19 379000000 -2.7 38 256 qam 31
20 387000000 -2.7 38 256 qam 32
21 395000000 -2.5 38 256 qam 33
22 403000000 -2.5 38 256 qam 34
23 411000000 -2.5 38 256 qam 35
24 419000000 -2.5 38 256 qam 36
1 Locked 38.9 100 0
2 Locked 38.9 107 0
3 Locked 38.9 108 0
4 Locked 38.9 80 0
5 Locked 38.9 81 0
6 Locked 38.9 90 0
7 Locked 38.9 139 0
8 Locked 38.9 344 0
9 Locked 38.6 345 13
10 Locked 38.9 289 0
11 Locked 38.9 282 0
12 Locked 38.9 283 0
13 Locked 38.9 292 0
14 Locked 38.6 298 0
15 Locked 38.6 41731 1605
16 Locked 38.9 51652 216
17 Locked 38.9 1823 778
18 Locked 38.9 643 12
19 Locked 38.9 390 13
20 Locked 38.9 396 329
21 Locked 38.9 9996 128
22 Locked 38.6 38245 10525
23 Locked 38.9 38859 21533
24 Locked 38.6 38644 13734
1 60300000 45.5 5120 64 qam 1
2 53699905 45 5120 64 qam 2
3 39400000 44.3 5120 64 qam 4
4 46200000 44.5 5120 64 qam 3
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 1 0
4 ATDMA 0 0 3 0
on 17-09-2021 13:47
on 17-09-2021 13:49
on 18-09-2021 16:22
Hi, I figured that I should go modem mode with a standalone router anyway, as so many seem to have problems with work VPNs.
new monitor setup with hub3 in modem mode
Got a TPLink AX1500 , seems like it should be all automatic to connect up, but it failed to find the internet.
So I found what my current settings were for internet connection in modem mode , IP, Subnet, Gateway,DHCP,DNS etc. and set it up manually.
That worked OK and all reconnected again ok after powering everything off for 5 mins, but now my question is: will these static settings remain correct or will my address be changed dynamically at some point and I should be looking to resolve the dynamic setup problem with the TPLink router?
18-09-2021 22:51 - edited 18-09-2021 22:55
Looks like VM are not doing DAI for your area?
I guess you got the IP settings with the hub in router mode or modem mode with a PC yet the MAC of the TPLink allowed it for them IP settings which really should not happen.
I suggest turning off the hub for 2min change your router to DHCP then turn hub back on.
on 19-09-2021 12:40
ok, I've set it back to automatic and its worked this time.
The host IP changed again so I've made a new BQM graph
Ready to test work vpn connections from tomorrow.
on 21-09-2021 12:55
Hi @g142,
Welcome to our community forums and thank you for your first posts.
Sorry to hear you have been experiencing disconnections on your service. We can understand this s not ideal and we want to best help. Has service improved since your last post with the changes made?
Please get back to me when you can.
on 21-09-2021 16:45
The system has been much more stable with the hub in modem mode and my own router in place.
I had only one disconnect on Monday, and another today but I think there was a general outage in the area today that caused that.
on 23-09-2021 16:52
Hi @g142,
Thank you for the update. I am glad to hear that things have now improved for you.
If you need any further assistance and support, please do let us know.
