vordhosbn91
change wifi password - ethernet cable
Hi I need to change my wifi password but i do not have an ethernet cable on my laptop. Is there a way I can change it without having to use this cable? Its quite urgent. I also cannot find any way to access the live chat/ messenger seems impossible! Thanks
Andrew-G
  • 6.13K
  • 1.08K
  • 2.6K
Re: change wifi password - ethernet cable
Log in to the hub at http://192.168.0.1/  That should pull up the log in page for the hub.  Doesn't need to be over ethernet.
gary_dexter
  • 30.49K
  • 1.89K
  • 4.05K
can you not connect to the Wifi?
