on 12-11-2021 09:59
Hi an update regarding our Red light on hub3 .
The engineer came promptly on the 15th oct and diagnosed the red light indicated a firmware update fail additionally also detected a poor broadband strength, he did a external check from the main junction box and said our issues were due to a faulty cable from the junction box down the road to our house.
He then ordered a re-pull to replace our cable on the 28th Oct.
No one turned up on the 28th at the end of the day we received a text to say they were not coming till the 11th Nov.
No one turned up on the 11th i chased this via whats app and then received a text to say they now are not going to come till the 25th Nov !
This now means we will be expected to endure a slow to intermittent to no broadband for a homeworking household for about 6 weeks.
I think you would agree this cant be right ?
thanks
Ian
Answered! Go to Answer
on 12-11-2021 11:23
who can argue with a tech and i certainly cannot on the cable repull - i assume he did some tests but in the light of his other comment that a firmware update is causing the red light on the hub3 then the rest is open to question
a red light is caused by the led and its circuit being faulty or the hub is reporting its over heating - thats assuming you are not in modem mode
did he change the hub and if so has the red light gone back to white or do you still have the original hub with a red light - if so it wants changing - the thread has been flagged so let VM get involved with that
as to poor speeds or whatever - how are you testing - wired or wifi - post some info
log into hub3 - 192.168.0.1 [or 192.168.100.1 if in modem mode] - DON'T SIGN IN, click - click router status [centre of screen] - and post the downstream and upstream figures - to see those press on the grey buttons/boxes labelled - upstream - downstream
if its an earlier hub button is top right
it may well be that the cable needs replacing and [again] VM can look at that but the urgent bit is to replace the hub if it still has a red light
on 12-11-2021 11:23
on 12-11-2021 11:58
Hello again 90110
After our Pm this morning regarding the repull
I was needing to arrange an engineer to attend to swap this hub over
The red light does indeed mean a fault with the hub
As we have passed security already I shall book an engineer back out and PM you the appointment time
Gareth_L
on 12-11-2021 12:03
Hello again 90110
The repull being booked on will not allow an appointment to be booked in
Can you please
Try a pinhole reset on the Hub
Make sure the hub is well ventilated and not in direct sunlight
Once the hub has settled down
Can you please let me know if the light is still showing red
Sorry to have messed you about
Gareth_L
on 12-11-2021 13:17
@Gareth_L wrote:Hello again 90110
Can you please
Gareth_L
with respect - here we go again - do a reset - yes i know its a good idea but its not going to change the light colour - the earlier tech wants sorting - he was talking rubbish if he did not know taht he needs some training
will you be happy on behalf of VM @Gareth_L if the hub catches fire - are you prepared to take that responsibility - i hope so - if not find a way to get a tech there or post a hub out
on 12-11-2021 15:25
I have done the pinhole reset and the light has still remained red. The hub has always been in an open space out of the sun.
I have read tonys post on the forum who seems to think the red light could be a safety issue?
As i said in the private chat we have to use the broadband for home working (even though it is intermittent and slow) so cannot leave it off.
Please can we resolve this as a priority.
Thank you
Ian
on 12-11-2021 16:25
have flagged the thread again in the mean time
with the poor info from the tech about the red light lets see the levels - it may be the repull is also a figment of his imagination
on 12-11-2021 16:38
Thanks for flagging again Tony
Hi 90110
I have mailed the Field Manager for your area
Explained the situation as the last Technician should have swapped the Hub over
As we have a repull booked in we are unable to manually book another appointment util it had been completed
So I needed to escalate this for you
I cannot say exactly when we will be round only other than as soon as possible
Gareth_L
