on 06-09-2021 12:51
on 06-09-2021 12:59
There's no good reason why it shouldn't work - but I should point out that this is only a fast ethernet switch and not a gigabit one, so if you have upgraded to the 1 Gbit tier, then anything you connect to that switch will only transfer data at roughly one tenth of what you are paying for!
on 06-09-2021 13:44
Thanks but I'm getting nothing from the zyxel switch plugged into the hub 4 (not even 1 tenth), it worked fine before the replacement of the hub
on 06-09-2021 13:46
