on 02-08-2022 09:42
If using the Zoom app on my iPhone on my Wifi or on my laptop via ethernet connectivity, zoom is very unstable.
If I switch Wi-Fi off on my phone, Zoom works fine with mobile data.
I have the 1GB package and any help would be much appreciated
on 02-08-2022 09:54
25 | 330750000 | 7.099998 | 38.983261 | QAM256 | 25 |
1 | 138750000 | 5.900002 | 37.636276 | QAM256 | 1 |
2 | 146750000 | 5.900002 | 37.636276 | QAM256 | 2 |
3 | 154750000 | 6.199997 | 38.605377 | QAM256 | 3 |
4 | 162750000 | 6.099998 | 38.605377 | QAM256 | 4 |
5 | 170750000 | 5.699997 | 38.605377 | QAM256 | 5 |
6 | 178750000 | 5.599998 | 38.605377 | QAM256 | 6 |
7 | 186750000 | 5.699997 | 38.605377 | QAM256 | 7 |
8 | 194750000 | 5.699997 | 38.605377 | QAM256 | 8 |
9 | 202750000 | 5.699997 | 38.983261 | QAM256 | 9 |
10 | 210750000 | 5.800003 | 38.605377 | QAM256 | 10 |
11 | 218750000 | 5.800003 | 38.983261 | QAM256 | 11 |
12 | 226750000 | 5.800003 | 38.983261 | QAM256 | 12 |
13 | 234750000 | 5.800003 | 38.983261 | QAM256 | 13 |
14 | 242750000 | 6.000000 | 38.983261 | QAM256 | 14 |
15 | 250750000 | 6.099998 | 38.983261 | QAM256 | 15 |
16 | 258750000 | 6.300003 | 38.983261 | QAM256 | 16 |
17 | 266750000 | 6.500000 | 38.605377 | QAM256 | 17 |
18 | 274750000 | 6.599998 | 38.983261 | QAM256 | 18 |
19 | 282750000 | 6.599998 | 38.983261 | QAM256 | 19 |
20 | 290750000 | 6.500000 | 38.983261 | QAM256 | 20 |
21 | 298750000 | 6.599998 | 38.605377 | QAM256 | 21 |
22 | 306750000 | 6.699997 | 38.983261 | QAM256 | 22 |
23 | 314750000 | 6.800003 | 38.983261 | QAM256 | 23 |
24 | 322750000 | 7.099998 | 38.983261 | QAM256 | 24 |
26 | 338750000 | 7.199997 | 38.983261 | QAM256 | 26 |
27 | 346750000 | 6.900002 | 38.983261 | QAM256 | 27 |
28 | 354750000 | 7.000000 | 38.983261 | QAM256 | 28 |
29 | 362750000 | 7.000000 | 40.366287 | QAM256 | 29 |
30 | 370750000 | 6.800003 | 40.366287 | QAM256 | 30 |
31 | 378750000 | 6.900002 | 40.946209 | QAM256 | 31 |
25 | Locked | 38.983261 | 0 | 0 |
1 | Locked | 37.636276 | 2 | 0 |
2 | Locked | 37.636276 | 0 | 0 |
3 | Locked | 38.605377 | 0 | 0 |
4 | Locked | 38.605377 | 0 | 0 |
5 | Locked | 38.605377 | 0 | 0 |
6 | Locked | 38.605377 | 0 | 0 |
7 | Locked | 38.605377 | 0 | 0 |
8 | Locked | 38.605377 | 0 | 0 |
9 | Locked | 38.983261 | 0 | 0 |
10 | Locked | 38.605377 | 80889 | 0 |
11 | Locked | 38.983261 | 0 | 0 |
12 | Locked | 38.983261 | 0 | 0 |
13 | Locked | 38.983261 | 0 | 0 |
14 | Locked | 38.983261 | 0 | 0 |
15 | Locked | 38.983261 | 0 | 0 |
16 | Locked | 38.983261 | 0 | 0 |
17 | Locked | 38.605377 | 0 | 0 |
18 | Locked | 38.983261 | 0 | 0 |
19 | Locked | 38.983261 | 0 | 0 |
20 | Locked | 38.983261 | 0 | 0 |
21 | Locked | 38.605377 | 0 | 0 |
22 | Locked | 38.983261 | 0 | 0 |
23 | Locked | 38.983261 | 0 | 0 |
24 | Locked | 38.983261 | 0 | 0 |
26 | Locked | 38.983261 | 0 | 0 |
27 | Locked | 38.983261 | 0 | 0 |
28 | Locked | 38.983261 | 0 | 0 |
29 | Locked | 40.366287 | 0 | 0 |
30 | Locked | 40.366287 | 0 | 0 |
31 | Locked | 40.946209 | 0 | 0 |
33 | 94 | 4K | 1840 | QAM4096 | 424 |
33 | Locked | 42 | 6.5 | 1103296899 | 49 |
on 02-08-2022 09:55
1 | 32600000 | 42.020599 | 5120 KSym/sec | 64QAM | 3 |
2 | 46200000 | 42.270599 | 5120 KSym/sec | 64QAM | 1 |
3 | 39400000 | 42.270599 | 5120 KSym/sec | 64QAM | 2 |
4 | 25800000 | 41.770599 | 5120 KSym/sec | 32QAM | 4 |
1 | US_TYPE_STDMA | 0 | 0 | 1 | 0 |
2 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
3 | US_TYPE_STDMA | 0 | 0 | 1 | 0 |
4 | US_TYPE_STDMA | 0 | 0 | 4 | 0 |
02-08-2022 13:35 - edited 02-08-2022 13:36
Looks like an issue on the upstream connection. One channel has dropped to 32 qam and there are too many T3 errors. Try this
______________________________
Switch the Hub off and unplug it from the mains supply for five minutes. Whilst it's off, do a quick check that all of your coax and ethernet cable connections are in nice and "finger" tight - at the Hub and wall box and also at any connectors etc. Ensure there are no “unterminated cable loose ends. Disconnect all the connections and reconnect to be sure. Also check that the internal wiring is ok with no kinking or chaffing, check that all looks good with the outside cabling and wall box (no “staples, etc.,) piercing the cables. Then switch the Hub back on and leave ~5 minutes
When all done, check back in the settings and see if all the Up qams are at 64 - they should be - also ensure that any RS error counts and T3 errors have all reset to 0. Then check every hour or so to see if they start reappearing - they shouldn't. If they do (particularly the postRS and T3 ones) you have a problem (noise) that only a Tech visit will sort.
on 03-08-2022 09:57
Thanks for the advice, I have done this and its looking OK, will test Zoom
2 | 46200000 | 42.020599 | 5120 KSym/sec | 64QAM | 1 |
3 | 25800000 | 41.770599 | 5120 KSym/sec | 64QAM | 4 |
4 | 39400000 | 42.020599 | 5120 KSym/sec | 64QAM | 2 |
1 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
3 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
4 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
on 05-08-2022 15:57
Hey @sontait,
Welcome back to the community and thanks for taking the time to post.
I'm sorry to hear of the issues that you're having with Zoom calls, are you having issues with any other applications or is just a problem that is happening with Zoom?
I ask this as I have looked into this and there is an SNR issue in your area that has a current estimate fix date of Monday 8th August at 11.10am, hopefully once this has been resolved, the issues that you're having should stop.
Regards,
Steven_L
