Darkside99x
  • 5
Message 1 of 11
Wireless has started failing frequently
Hi, around 2 weeks ago I got major connection issues with the router for around a 24 hour period where my net barely worked.
Following that the wired connections are mostly back to normal baring some major but brief bandwidth drops every few days, the wireless however is not working well at all since.
Mobile devices lose signal entirely every few minutes for 10-30 seconds and my steamlink which I use to stream my PC (which has worked flawlessly for years) is also having connection issues and giving back an error with the wireless rather than a normal no signal.
Any help would be appreciated.
Darkside99x
  • 5
Message 2 of 11
Re: Wireless has started failing frequently
I should also point out I've tried the usual fixes for the router, including the service test which did detect an issue with the broadband and rebooted the hub but no longer detects an issue and the problem persists.
lotharmat
  • 902
  • 61
  • 133
Well-informed
Message 3 of 11
Sounds like the hub is on the way out.
I assume that when WiFi drops it drops for everything at the same time?
Also - when WiFi does drop out - what lights (if any) are showing on the hub?
Darkside99x
  • 5
Message 4 of 11
Yeah the wireless drops across the board, my hub only ever seems to have the power light on except when it’s restarted.
lotharmat
  • 902
  • 61
  • 133
Well-informed
Message 5 of 11
Definitely sounds like the WiFi part of the hub is dying! - Mine did this albeit with the WiFi light on the Hub (3) flashing green.
Darkside99x
  • 5
Message 6 of 11
I suspected so.
Do I need to contact someone specific about it or wait until someone from VM comments here?
Cheers.
lotharmat
  • 902
  • 61
  • 133
Well-informed
Message 7 of 11
VM Should pick this up shortly!
Zoie_P
  • 2.49K
  • 118
  • 196
Message 8 of 11
Hi Darkside99x,
Thanks for your post, I have check your account and can see there is a stability issue, we need to get this resolved I will pop you over a PM and we can go from there,
Zoie
Darkside99x
  • 5
Message 9 of 11
Hey, I sent you the requested info on Friday evening and havent heard back.
A Virgin Engineer has visited my nieghbour twice this week though and let me know theres a major issue with the local area at present, would that be causing just my WiFi to cut out though?
Zoie_P
  • 2.49K
  • 118
  • 196
Message 10 of 11
Hi Darkside99x,
I am sorry for the delay I have sent a reply, and we will get an engineer out as I have checked and your downstream levels are low.
Zoie
