modoego
Wired connection not working
I’m trying to use a wired connection and I’ve plugged my Ethernet into the hub and my laptop but the laptop is showing it as ‘unidentified network No internet’.  Is there something else I have to do to make it work?  The wifi is working fine and there are flashing green light on the port I’m using on the hub.  I’ve tried different ports.
  • 3.19K
  • 249
  • 694
Re: Wired connection not working
Make sure the laptop network is set to DHCP.   Also try a different Cat 6 network cable, as they can fail.
modoego
Brilliant thank you, the DHCP setting was exactly the problem, now on the 5G!  Why wasn’t that info anywhere on the website?  All I could find was that I should just connect the cable and that was it.  Thanks again
Akua_A
  • 1.22K
  • 31
  • 79
Hi @modoego,
Welcome to our community forums and thank you for your first posts.
Sorry to hear you were having issues connecting by ethernet cable. We are however glad to see that @Adduxi was able to help regarding this.
Please do not hesitate to contact us if you need any further help.
Akua_A
