on 11-06-2022 09:37
Hi I have a super hub 3 used as a router and recently wired and wireless connections have been freezing and dropping. I have tried resetting and new Ethernet cables. Here are the router stats.
1 | 323000000 | -1 | 40 | 256 qam | 24 |
2 | 203000000 | -1.9 | 40 | 256 qam | 9 |
3 | 211000000 | -1.7 | 38 | 256 qam | 10 |
4 | 219000000 | -1.9 | 40 | 256 qam | 11 |
5 | 227000000 | -1.9 | 38 | 256 qam | 12 |
6 | 235000000 | -2 | 38 | 256 qam | 13 |
7 | 243000000 | -2.2 | 38 | 256 qam | 14 |
8 | 251000000 | -2.2 | 40 | 256 qam | 15 |
9 | 259000000 | -2 | 38 | 256 qam | 16 |
10 | 267000000 | -1.7 | 40 | 256 qam | 17 |
11 | 275000000 | -1.7 | 40 | 256 qam | 18 |
12 | 283000000 | -1.5 | 40 | 256 qam | 19 |
13 | 291000000 | -1.5 | 38 | 256 qam | 20 |
14 | 299000000 | -1.5 | 38 | 256 qam | 21 |
15 | 307000000 | -1.4 | 40 | 256 qam | 22 |
16 | 315000000 | -1.2 | 40 | 256 qam | 23 |
17 | 331000000 | -1.2 | 38 | 256 qam | 25 |
18 | 339000000 | -1.2 | 40 | 256 qam | 26 |
19 | 347000000 | -1.2 | 38 | 256 qam | 27 |
20 | 355000000 | -1 | 38 | 256 qam | 28 |
21 | 363000000 | -0.7 | 40 | 256 qam | 29 |
22 | 371000000 | -0.4 | 40 | 256 qam | 30 |
23 | 379000000 | -0.2 | 40 | 256 qam | 31 |
24 | 387000000 | -0.4 | 40 | 256 qam | 32 |
1 | Locked | 40.9 | 1268151 | 145952 |
2 | Locked | 40.3 | 6215212 | 545044 |
3 | Locked | 38.9 | 5523607 | 458149 |
4 | Locked | 40.3 | 5146886 | 401677 |
5 | Locked | 38.6 | 4994466 | 380156 |
6 | Locked | 38.9 | 4481695 | 322263 |
7 | Locked | 38.9 | 3872675 | 265008 |
8 | Locked | 40.3 | 3495495 | 229769 |
9 | Locked | 38.9 | 3216398 | 200332 |
10 | Locked | 40.3 | 2902552 | 196589 |
11 | Locked | 40.3 | 2540098 | 176990 |
12 | Locked | 40.9 | 2124776 | 166146 |
13 | Locked | 38.9 | 2000656 | 160300 |
14 | Locked | 38.9 | 1795990 | 154069 |
15 | Locked | 40.9 | 1583930 | 149187 |
16 | Locked | 40.3 | 1424898 | 150233 |
17 | Locked | 38.9 | 1126132 | 138944 |
18 | Locked | 40.3 | 975254 | 130766 |
19 | Locked | 38.9 | 844158 | 134506 |
20 | Locked | 38.9 | 717350 | 132912 |
21 | Locked | 40.3 | 593153 | 134560 |
22 | Locked | 40.3 | 497869 | 131807 |
23 | Locked | 40.3 | 422459 | 127566 |
24 | Locked | 40.3 | 260091 | 120190 |
1 32600000 42 5120 64 qam 5
2 53700078 43.5 5120 64 qam 2
3 46200000 43 5120 64 qam 3
4 39399990 42.5 5120 64 qam 4
1 ATDMA 0 0 42 0
2 ATDMA 0 0 16 0
3 ATDMA 0 0 30 0
4 ATDMA 0 0 28 0
11/06/2022 03:39:58 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/06/2022 02:11:57 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/06/2022 02:07:30 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/06/2022 02:07:30 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
Here is a think broadband graph for today.
do I need an engineer?
on 29-06-2022 18:56
Hi I did the pin hole reset but the drops are happening again.
1 | 323000000 | 2.5 | 40 | 256 qam | 24 |
2 | 139000000 | 1.2 | 38 | 256 qam | 1 |
3 | 147000000 | 1.4 | 40 | 256 qam | 2 |
4 | 155000000 | 1.5 | 40 | 256 qam | 3 |
5 | 163000000 | 1.5 | 40 | 256 qam | 4 |
6 | 171000000 | 1.5 | 40 | 256 qam | 5 |
7 | 179000000 | 1.5 | 40 | 256 qam | 6 |
8 | 187000000 | 1.5 | 40 | 256 qam | 7 |
9 | 195000000 | 1.5 | 40 | 256 qam | 8 |
10 | 203000000 | 1.2 | 40 | 256 qam | 9 |
11 | 211000000 | 1.4 | 40 | 256 qam | 10 |
12 | 219000000 | 1.5 | 40 | 256 qam | 11 |
13 | 227000000 | 1.5 | 40 | 256 qam | 12 |
14 | 235000000 | 1.2 | 40 | 256 qam | 13 |
15 | 243000000 | 1 | 40 | 256 qam | 14 |
16 | 251000000 | 1 | 40 | 256 qam | 15 |
17 | 259000000 | 1 | 40 | 256 qam | 16 |
18 | 267000000 | 1.5 | 40 | 256 qam | 17 |
19 | 275000000 | 1.5 | 40 | 256 qam | 18 |
20 | 283000000 | 1.9 | 40 | 256 qam | 19 |
21 | 291000000 | 2 | 40 | 256 qam | 20 |
22 | 299000000 | 2.2 | 40 | 256 qam | 21 |
23 | 307000000 | 2.2 | 40 | 256 qam | 22 |
24 | 315000000 | 2.5 | 40 | 256 qam | 23 |
1 | Locked | 40.3 | 23 | 0 |
2 | Locked | 38.9 | 482 | 0 |
3 | Locked | 40.3 | 306 | 0 |
4 | Locked | 40.3 | 206 | 0 |
5 | Locked | 40.3 | 194 | 0 |
6 | Locked | 40.9 | 190 | 0 |
7 | Locked | 40.3 | 116 | 0 |
8 | Locked | 40.9 | 126 | 0 |
9 | Locked | 40.3 | 101 | 0 |
10 | Locked | 40.9 | 60 | 0 |
11 | Locked | 40.3 | 61 | 0 |
12 | Locked | 40.9 | 31 | 0 |
13 | Locked | 40.3 | 33 | 0 |
14 | Locked | 40.3 | 38 | 0 |
15 | Locked | 40.3 | 28 | 0 |
16 | Locked | 40.3 | 40 | 0 |
17 | Locked | 40.3 | 32 | 0 |
18 | Locked | 40.3 | 122 | 0 |
19 | Locked | 40.3 | 29 | 0 |
20 | Locked | 40.3 | 20 | 0 |
21 | Locked | 40.9 | 21 | 0 |
22 | Locked | 40.9 | 26 | 0 |
23 | Locked | 40.3 | 27 | 0 |
24 | Locked | 40.3 | 33 | 0 |
1 | 53700000 | 47.3 | 5120 | 64 qam | 2 |
2 | 46200000 | 46.8 | 5120 | 64 qam | 3 |
3 | 39400000 | 46.5 | 5120 | 64 qam | 4 |
4 | 60300000 | 47.8 | 5120 | 64 qam | 1 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 1 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
15:11:57 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
27/06/2022 03:20:46 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/06/2022 06:20:19 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 29-06-2022 19:05
on 29-06-2022 19:18
https://www.thinkbroadband.com/broadband/monitoring/quality/share/16f3fcd37ff4c92c4a30055cda57bebc4ad02084
on 01-07-2022 20:20
Hi thewickedpicket
Thanks for posting - sorry to hear of the broadband issues. I've done a system check today and no issues are showing, no outages, all levels are fine and no issues with the congestion or SNR levels.
I did see on Wednesday the latency spiked but it has gone back to normal levels since.
Has everything been sorted? Let us know if we can assist further.
Best,
on 01-07-2022 20:24
Hi It seemed to be a WiFi issue so I’ve just put the router in modem mode and installed an ASUS ax88u router for WiFi. Hopefully this will fix things.
