Wired (and wireless)broadband drop off issues
thewickedpicket
Hi I have a super hub 3 used as a router and recently wired and wireless connections have been freezing and dropping. I have tried resetting and new Ethernet cables. Here are the router stats.
1323000000-140256 qam24
2203000000-1.940256 qam9
3211000000-1.738256 qam10
4219000000-1.940256 qam11
5227000000-1.938256 qam12
6235000000-238256 qam13
7243000000-2.238256 qam14
8251000000-2.240256 qam15
9259000000-238256 qam16
10267000000-1.740256 qam17
11275000000-1.740256 qam18
12283000000-1.540256 qam19
13291000000-1.538256 qam20
14299000000-1.538256 qam21
15307000000-1.440256 qam22
16315000000-1.240256 qam23
17331000000-1.238256 qam25
18339000000-1.240256 qam26
19347000000-1.238256 qam27
20355000000-138256 qam28
21363000000-0.740256 qam29
22371000000-0.440256 qam30
23379000000-0.240256 qam31
24387000000-0.440256 qam32
1Locked40.91268151145952
2Locked40.36215212545044
3Locked38.95523607458149
4Locked40.35146886401677
5Locked38.64994466380156
6Locked38.94481695322263
7Locked38.93872675265008
8Locked40.33495495229769
9Locked38.93216398200332
10Locked40.32902552196589
11Locked40.32540098176990
12Locked40.92124776166146
13Locked38.92000656160300
14Locked38.91795990154069
15Locked40.91583930149187
16Locked40.31424898150233
17Locked38.91126132138944
18Locked40.3975254130766
19Locked38.9844158134506
20Locked38.9717350132912
21Locked40.3593153134560
22Locked40.3497869131807
23Locked40.3422459127566
24Locked40.3260091120190
1 32600000 42 5120 64 qam 5
2 53700078 43.5 5120 64 qam 2
3 46200000 43 5120 64 qam 3
4 39399990 42.5 5120 64 qam 4
1 ATDMA 0 0 42 0
2 ATDMA 0 0 16 0
3 ATDMA 0 0 30 0
4 ATDMA 0 0 28 0
11/06/2022 03:39:58ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/06/2022 02:11:57Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/06/2022 02:07:30criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/06/2022 02:07:30Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Here is a think broadband graph for today.
do I need an engineer?
14 REPLIES 14
Anonymous
Not applicable
The volume of post RS errors and T3 timeouts is quite something.
Try another 30 second pinhole reset of the hub without any ethernet connection. Also check for local issues on 0800 561 0061. Lastly make sure all cables and connections are tight and secure and not kinked or damaged.
After trying these let us know how you get on but you might well need an engineer.
Thanks I did a reset as you suggested yesterday. Here are the results today
13260000047512064 qam5
25370001448.3512064 qam2
34619999648.3512064 qam3
43940000047.8512064 qam4
1ATDMA00530
2ATDMA00160
3ATDMA00120
4ATDMA00180
1323000000-2.240256 qam24
2203000000-4.440256 qam9
3211000000-4.238256 qam10
4219000000-438256 qam11
5227000000-438256 qam12
6235000000-4.238256 qam13
7243000000-4.238256 qam14
8251000000-438256 qam15
9259000000-3.938256 qam16
10267000000-3.438256 qam17
11275000000-3.238256 qam18
12283000000-340256 qam19
13291000000-338256 qam20
14299000000-2.738256 qam21
15307000000-2.740256 qam22
16315000000-2.540256 qam23
17331000000-2.438256 qam25
18339000000-2.440256 qam26
19347000000-2.238256 qam27
20355000000-240256 qam28
21363000000-1.540256 qam29
22371000000-1.240256 qam30
23379000000-140256 qam31
24387000000-140256 qam32
1Locked40.311459994667
2Locked40.3185744147351
3Locked38.6174480139805
4Locked38.9167555136196
5Locked38.9170143135627
6Locked38.9162722130350
7Locked38.9150508127328
8Locked38.9143740123824
9Locked38.9139379120715
10Locked38.9138362116464
11Locked38.9130356115024
12Locked40.9122433110646
13Locked38.9122286108579
14Locked38.9121523103744
15Locked40.312052097344
16Locked40.311726296061
17Locked38.911199891651
18Locked40.310577989948
19Locked38.910402989961
20Locked40.39992386138
21Locked40.39567987645
22Locked40.39240783158
23Locked40.39200681095
24Locked40.989328
12/06/2022 05:04:27Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/06/2022 05:04:25Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/06/2022 03:09:52Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/06/2022 03:09:52criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/06/2022 03:08:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Anonymous
Not applicable
Ugh well no change there.
Did you manage to check for any local faults?
Yeah everything fine apparently 🤔
So all is fine at the wider level - and the fault is specific to you (or a very small number of customers).
That amount of RS errors sugests "noise/" is getting in somewhere.  There are many reasons why this can happen  For example you or your neighbours using non-VM cable to extend their Hub position, a bad connection on one of the connectors, a damaged cable somewhere, etc.
So all you can do without a Tech visit is do a quick check that all of your coax cable connections are in nice and "finger" tight - at the Hub and wall box and also at any connectors etc. Disconnect all the connections and reconnect to be sure. Ensure there are no “unterminated cable loose ends or loose wires on the connectors . Also check that the internal wiring is ok with no kinking or chaffing, check that all looks good with the outside cabling (no clips piercing, or broken sheathing) and the wall box
Thanks. Appreciate the help.
Thanks for confirming your details via private message @thewickedpicket.
I have arranged for the appointment, and you can track your engineer appointments online. Simply sign into My Virgin Media and you’ll see your appointments on your account dashboard. However, this can take up to 24 hours to be updated.
Regards,
Steven_L
Hi an engineer came on Friday and replaced cable connections at the router and at outside. This fixed the problem until now. The timeouts have started happening again. Here are the router stats.
13230000002.540256 qam24
22030000001.240256 qam9
32110000001.240256 qam10
42190000001.540256 qam11
52270000001.440256 qam12
62350000001.240256 qam13
72430000000.940256 qam14
82510000000.940256 qam15
9259000000140256 qam
16
13260000045.8512064 qam5
25370000047.5512064 qam2
34620019447512064 qam3
43940000046.5512064 qam4
1ATDMA0010
2ATDMA0020
3ATDMA0000
4ATDMA0030
22/06/2022 22:01:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2022 11:04:31ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/06/2022 21:09:52criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/06/2022 12:08:50ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Hi thewickedpicket,
I'm sorry to hear you're still experiencing some connections issues.
I've been through a couple of checks from our side, and can you please perform a pin hole reset?
Let us know if you continue to have any connection problems after.
Alex_Rm
