on 01-09-2021 10:32
Hi there,
I've recently moved into a rental property which already had a Virgin wall socket installed, so I went for a self install and everything has worked great with the kit Virgin provided.
I did notice a cable that runs from the wall socket through to another room that was installed before we moved in (runs along the walls). I was hesitant to try plugging it in in case of any issues and just used what Virgin provided- but it looks like it may have been installed to plug in the router into another room for better coverage across the house. The cable has text that reads "Cablecon 3.9" on both ends.
Cable near Wall socket:
Cable in the other room:
If anyone knows if this is suitable or what this if for that would be a big help!
Alex
on 01-09-2021 12:23
You can use that cable for tv and broadband, just make screwed in tight
