on 18-08-2022 21:15
I have wifi normally but I can't connect to the internet to any device with the ethernet cables
on 18-08-2022 21:24
Try a pin hole reset of the hub.
on 18-08-2022 21:32
Yeah I've tried that already and I still have that problem
on 18-08-2022 22:06
Please try the following exactly as typed.
Disconnect ALL ethernet cables from the Hub.
With the Hub powered on use a paperclip, or a mobile sim slot tool and perform a pinhole reset by keeping it pressed in for a timed 60 seconds
DO NOT reboot the hub but allow it 8 to 10 minutes to boot up and settle down.
