on 27-08-2021 16:12
Dear All,
Is anyone else constantly having their internet connection dropout regardless of you are connected via Wifi or LAN cable ? I have now had this problem coming up for over a week, but the last 2 days have been horrible with connecting dropping quite frequently (every 5 - 10 mins).
The constant drop out is making it very hard to do anything, especially WFH as the VPN connecting to work is lost each time. I have tried all of the usual things like rebooting the router, resetting to factory setting, but the problems seems to continue and affecting everyone in the house.
What is now even strange is that the Virgin TV signal has also started to play up as you can see in thel inked picture / video with distorted signal - The Tivo box actually shows signal strength of 93% when I was having these distorted images !!
https://ibb.co/h1MpHjL
https://streamable.com/kz0hh2
Any ideas on what the cause could be, or the solution as I am now having to think about getting a Mobile WiFi unit as cannot continue WFH with such a poor and unreliable WiFi, and no longer able to watch certain channels on Virgin due to the signal issues.
The below is status on the router :
Acquired Downstream Channel (Hz) | 203000000 | Locked |
Ranged Upstream Channel (Hz) | 32600055 | Locked |
Provisioning State | Online |
1 | 203000000 | -1.7 | 38 | 256 qam | 9 |
2 | 211000000 | -1.7 | 38 | 256 qam | 10 |
3 | 219000000 | -1.9 | 38 | 256 qam | 11 |
4 | 227000000 | -2 | 38 | 256 qam | 12 |
5 | 235000000 | -2.4 | 38 | 256 qam | 13 |
6 | 243000000 | -2.9 | 38 | 256 qam | 14 |
7 | 251000000 | -3.7 | 38 | 256 qam | 15 |
8 | 259000000 | -4.4 | 37 | 256 qam | 16 |
9 | 267000000 | -3.2 | 38 | 256 qam | 17 |
10 | 275000000 | -3 | 38 | 256 qam | 18 |
11 | 283000000 | -2.7 | 38 | 256 qam | 19 |
12 | 291000000 | -2.7 | 38 | 256 qam | 20 |
13 | 299000000 | -2.5 | 38 | 256 qam | 21 |
14 | 307000000 | -2.9 | 38 | 256 qam | 22 |
15 | 315000000 | -2.7 | 37 | 256 qam | 23 |
16 | 323000000 | -3 | 37 | 256 qam | 24 |
17 | 331000000 | -3 | 37 | 256 qam | 25 |
18 | 371000000 | -3.5 | 37 | 256 qam | 26 |
19 | 379000000 | -4.7 | 37 | 256 qam | 27 |
20 | 387000000 | -5.2 | 37 | 256 qam | 28 |
21 | 395000000 | -5.2 | 36 | 256 qam | 29 |
22 | 403000000 | -5 | 37 | 256 qam | 30 |
23 | 411000000 | -4.9 | 36 | 256 qam | 31 |
24 | 419000000 | -4.7 | 37 | 256 qam | 32 |
1 | Locked | 38.9 | 9 | 0 |
2 | Locked | 38.9 | 21 | 0 |
3 | Locked | 38.6 | 13 | 0 |
4 | Locked | 38.6 | 9 | 0 |
5 | Locked | 38.6 | 10 | 0 |
6 | Locked | 38.6 | 9 | 0 |
7 | Locked | 38.6 | 9 | 0 |
8 | Locked | 37.6 | 24 | 0 |
9 | Locked | 38.6 | 18 | 0 |
10 | Locked | 38.6 | 10 | 0 |
11 | Locked | 38.6 | 13 | 0 |
12 | Locked | 38.9 | 8 | 0 |
13 | Locked | 38.6 | 18 | 0 |
14 | Locked | 38.6 | 12 | 0 |
15 | Locked | 37.6 | 13 | 0 |
16 | Locked | 37.3 | 28 | 0 |
17 | Locked | 37.6 | 3 | 0 |
18 | Locked | 37.3 | 15 | 0 |
19 | Locked | 37.3 | 10 | 0 |
20 | Locked | 37.3 | 45 | 0 |
21 | Locked | 36.6 | 34 | 0 |
22 | Locked | 37.3 | 28 | 0 |
23 | Locked | 36.6 | 19 | 0 |
24 | Locked | 37.3 | 26 | 0 |
on 29-08-2021 19:23
Hi, I’ve posted about an identical problem. My BQM looks very similar to yours, Sohan. The red bars usually coincide with the green flashing lights on my hub 3, but not always.
on 29-08-2021 19:27
Thanks - I wonder if this is a recent common problem with virgin ?
my router only shows the green light when I reboot the router before it establishes connection. Once this is done, I don’t get any other light apart from the solid red light
on 29-08-2021 19:34
Hi Sohan. My BQM shows the dropped packets red bar starting at around the same time as yours last night, 23:51, and my red bars today have been at similar times to yours. I’m in the Cardiff area
on 29-08-2021 19:38
Is yours only last night ?
I posted other pictures of mine and I have the same happen each day since I installed BQM. I think the pictures are still going through the admin approval but I have lost packets red bar for most part of the day apart from early morning and evening. I am in the Surrey area
on 29-08-2021 19:50
on 31-08-2021 08:10
Thanks for sending those details over,
I've arranged an engineer visit for you, you can view the time and date of your appointment via your online account here
Alex_Rm
on 31-08-2021 22:14
on 03-09-2021 08:41
Hello sohanp
Thanks for your post
I have been able to locate your Hub etc from here
Can I ask how the engineers visit went?
How is the connection now
Gareth_L
