mr33d
  • 5
Message 1 of 10
Wifi speeds lower with M500 than they were with M350
I used to have the M350 package with my Hub 3 in modem mode connected to an Asus RT-AC68U router which also provided a connection to a BT Home hub 5 re-configured to be a WAP.
Physically connected devices returned a speed of 385Mbps and WIFI speed tests for this setup returned regular results in excess of 380Mbps from both the router and the BT home hub WAP.
I recently upgraded to the M500 package and whilst the physically connected devices now connect at 550Mbps the WIFI results are disappointing to say the least.
From the WIFI on the Asus router the best speed I have obtained is in the region of 460Mbps and from the BT WAP the best I'm getting is 330Mbps.
Does anyone have any ideas as to why my WIFI performance is, in part, worse than it was when using M350 and at best still below 500Mbps when compared to a wired connection of 550Mbps
Or can anyone recommend a WAP that will allow me to obtain a higher speed?
Thanks in advance
g0akc
  • 862
  • 79
  • 168
Well-informed
Message 2 of 10
Re: Wifi speeds lower with M500 than they were with M350
Any QoS set on the router?
Have you changed or tried changing channels?
Check the environment with a Wi-Fi analyser app - see which channels are in use
I know a bit about Wi-Fi, Telecoms, and TV as I used to do it for a living but I'm not perfect so don't beat me up... If you make things you make mistakes!
  • 15.9K
  • 687
  • 1.56K
Message 3 of 10
Ask BT for your BT home hub WAP to increase the egress buffer for Wifi.
mr33d
  • 5
Message 4 of 10
Hi g0akc,
Thanks for the response,
No QoS is not enabled on the router and I'd previously used a WIFI analyser to identify the frequencies in use and moved the Asus router and BT WAP to seperate frequencies for both  2.4 and 5 Ghz networks.
Whats perplexing me is that everything was working well and that the only thing that has changed is the move from M350 to M500
gary_dexter
  • 30.24K
  • 1.87K
  • 4.02K
Message 5 of 10
If your wired speeds are fine then there’s not a line fault
g0akc
  • 862
  • 79
  • 168
Well-informed
Message 6 of 10
@mr33d wrote:
Hi g0akc,
Noted.
Bear in mind the Hub 5 maxes out at just over 400 mega bits/s with AC - disregard the theoretical max of AC wireless.
it was one of the best ISP WiFi routers when launched about 5 years ago but it’s a bit long in the tooth now, and ‘only’ has 3x3 antennas and so on
see here;
https://www.trustedreviews.com/reviews/bt-home-hub-5-performance-value-verdict-page-2
So you’re not far off the ballpark max
Now for most people over 300meg WiFi speed would be fine - depending what you’re doing with it
You can play around and try to optimise everything - look again at channels - orientation and so on
I’m not sure why you’re not getting quite the throughput you were before
Look also at LAN to LAN speed
Try a pinhole reset of the hub 5 - but you’ll need to reconfigure it afterwards - you can try to do a back up and restore on it - this is in case some background process is going on that wasn’t previously
look at your devices too
Up to you if you want to look at other APs such as a disc or whatever
mr33d
  • 5
Message 7 of 10
Understood and agreed, Thanks 🙂
mr33d
  • 5
Message 8 of 10
Thanks, I'm borrowing a device from a colleague to trial, just to see if that elimates the problem, as part of my testing I'll try the pinhole reset as well, I'll post my results once I'm finished, Thanks
mr33d
  • 5
Message 9 of 10
Re: Wifi speeds lower with M500 than they were with M350 - Resolved
Update as promised - The TP Link Archer A7 AC1750 dual band router I borrowed was configured as a WAP and used to replace the BT Home.
The results were impressive and immediate, I am now regulary getting speeds in excess of 500Mbps and the highest WIFI speed this far is 552Mbps.
I tried the pin reset and reconfigure of the BT home hub but its performance remained the same.
I now have two avenues to explore, 1. purchase my own AC1750 or 2. persuade my colleague to sell his to me.
Thanks to all for responding
g0akc
  • 862
  • 79
  • 168
Well-informed
Message 10 of 10
Thanks for the update.
Another option is to look at a later router such as a BT Smart Hub and configure that as a WAP like you did the Hub 5.
It might be cheaper.  Loads on eBay etc. ?
That’s what I’ve done.
I use a D Link router downstairs and a BT Smart Hub 2, as a switch/AP upstairs, connected via proper external cable - works well.
Otherwise progress the high performance AP as you’re doing...
