on 12-09-2021 18:32
HI. I have the 200mb internet however iv been doing few speed tests iver past few days and noticed that at various times of the day or if im in another room away from the router i get speeds of only upto 50mb. How do i resolve this issue?
on 12-09-2021 18:42
thats a big question - wifi can give any speed - but first you need to check what the wired speed is when the wifi speed is low - if that drops then the fault is down to VM - if not its a wifi problem
you can split the bands - turn off smart wifi and look to ube a non busy channel
near the hub you want to use the 5 band but that gets worse the farther away from the hub you are so then 2.4 is better
but 50 is maybe al you can get on the device you are using - have you had faster speeds in the same location
14-09-2021 19:11 - edited 14-09-2021 19:12
