on 20-05-2023 16:56
Hi I get issue with my Hub5 my TV and also TV box and Xbox one loss the connection with Virgin hub 5 after they not able to find my WiFi when I search for it until I have restarted the hub they will able to see it but could get to same issue in any time in minutes or hours.but with phone or laptop is working fine! Please could anyone help?
on 22-05-2023 19:20
Hi @Gaz7 thanks for your post here in the Community although we're sorry to hear of the concerns you've raised here regarding your connection.
Have things been resolved since your post? Do you know if this happens on a wired connection too or is it just wireless that this happens?
Many thanks
on 22-05-2023 19:45
Hi Tom
thanks to reply to my concerned. When was in a wired connection was fine but when changed room furniture I couldn't usu wired . I started using WiFi, my internet speed 250mg the issue started unfortunately most TV connection when using YouTube and my TV box also they started working fine then could any time disconnect and they don't see the my WiFi until restart the Hub !
Gaz
on 24-05-2023 20:07
Thank you @Gaz7
I have taken a look on our side and I can see there are a few issues that will require an engineer to take a look.
I will pop you a Private Message now so we can take a look, please keep an eye out for the envelope at the top of your screen alerting you to a new message.
on 25-05-2023 07:28
"not able to find my WiFi when I search"
Faced with this I'd conclude the Hub 5's WiFi has failed.
