on 21-09-2022 19:43
I’ve tried to download the connect app to order wifi pods after doing the wifi test as it shows poor coverage in a room I want to work in.
it won’t give me an option for a pod and when I ring the option I press just tells me I gave issues and hands up how can I order a pod?
on 21-09-2022 19:53
on 21-09-2022 20:14
How do I know what GB I’m on? Tried calling no use tried the app no use.
on 21-09-2022 20:54
on 21-09-2022 20:59
That’s al it says ?
on 22-09-2022 09:31
on 22-09-2022 19:00
it doesn’t work the website just takes me to max but doesn’t tell me what to do. The app doesn’t send the the link to order the pods and neither does it when I rang so what can I do?
on 23-09-2022 14:40
on 26-09-2022 08:07
Hey RachD86, thank you for reaching out and I am sorry to hear you are having some issues trying to get a pod ordered.
Not to worry I will be able to help you with this, I am going to send you a PM, please look out for the purple envelope. Thanks
Matt - Forum Team
New around here?
