on 23-05-2023 19:52
Hello,
Just received my first WiFi pod and it will not connect after multiple attempts to run the setup through the connect app. Just keeps timing out and then gives the option to 'try again'. Have rebooted the hub. Even tried a connection with the pod in the same room as the hub just to see if it would work there but nothing. Assuming a dud pod?!?
Appreciate any support can get on this.
Matt
on 26-05-2023 08:48
Hi Matt 👋
Welcome to the community! Thank you for posting.
Sorry to hear about these issues with your Wi-Fi pod connecting! We may just need to make sure that the pod is paired correctly so it can connect to the hub. If not, we can always arrange a replacement being sent to you!
I can send you a PM to confirm a few account details so we can investigate further and then offer some support. Thank you for your patience in the meantime!
I will do this for you now - you can find the PM in the top right corner of the page in your Inbox. 📩 We can then return to this public thread with another update when possible. Thank you for your patience in the meantime!
Wishing you all the best. 🌞
