on 04-09-2021 17:00
Hello,
Plugged the pod in which appears to work, however the hub 4.0 automatically changes the name of my 5 ghz band to the name of my 2.5 ghz band and greys out the ability to change the password of the 5 Ghz
When I change the name of the 5 Ghz band again, the router settings accept this, and the 5 Ghz band may appear on devices (my amp connects to it but I can't see it on my phone, however), for perhaps 10 seconds then the wifi bands disappear then only the name of the 2.5 band appears, and when I check the router settings again the 5 GHZ band name has been changed to that of the 2.5 Ghz name.
Is this normal behavior?
Does the router/pod now name both bands the same and intelligently connect devices to the 5 Ghz band when the signal is strong enough then switch to the 2.5 Ghz (under the same name) when further from the router?
The answers to these questions are not in the FAQ.
Thanks.
04-09-2021 17:07 - edited 04-09-2021 17:09
@rainio wrote:Hello,
Plugged the pod in which appears to work, however the hub 4.0 automatically changes the name of my 5 ghz band to the name of my 2.5 ghz band and greys out the ability to change the password of the 5 Ghz <snip>
I believe this is by design, the SSID etc has to be the same on both frequencies for the Pods to work.
See link here https://www.virginmedia.com/help/virgin-media-intelligent-wifi-pods-faqs#acc-c2942dbd-8a8d-4184-9d38...
on 04-09-2021 17:07
on 04-09-2021 17:12
Ah, thanks.
Where in your link is this, as I had a look but must have missed it?
04-09-2021 22:20 - edited 04-09-2021 22:21
@rainio wrote:Ah, thanks
Performance. - Check WiFi issues
